Cam chains
10 replies to this topic
  • skull1971
Posted December 27, 2010 - 02:55 PM
Cam chain question,, 08 yz450,, is the stock chain good enough, or would an after market be better. I see there is a big difference in cost, but does that equil quality?
  • myoung
Posted December 27, 2010 - 05:27 PM
OEM is cheap enough, why bother with aftermarket?
  • crf450319
Posted December 27, 2010 - 07:28 PM
I just went through the same thing this past Fall, I had 60 hours on my original cam chain and wanted to replace it. I went with another OEM chain, ordered 2 at the same time and now I've got a new spare in my tool box. I'll run the chain that's in my bike for 50 to 60 hours and replace i again.
My original cam chain had 6 or 7 links that were starting to bind (very noticeably by hand) when I pulled it out & only had 60 hours on it.
  • Gunner354
Posted December 28, 2010 - 02:26 PM
What oil are you using. I have an 09 with over 350 hours and has never been opened up for a cam chain or anything.
  • mywifefarts
Posted December 28, 2010 - 02:52 PM
I just went through the same thing this past Fall, I had 60 hours on my original cam chain and wanted to replace it. I went with another OEM chain, ordered 2 at the same time and now I've got a new spare in my tool box. I'll run the chain that's in my bike for 50 to 60 hours and replace i again.If you don't mind me asking, what type of riding do you do and how many hours do put on your bike in a season or for that matter how many hours before buying a new bike?
I can't help but to ask you also. What type of riding and at what level? 350 hr.s is mighty impressive! That makes me feel good about my bike all over again.:excuseme:
  • crf450319
Posted December 28, 2010 - 02:58 PM
I run Amsoil MCF, change it and the filter every 6.5 to 7 hours of runtime. I ride MX only and run Intermediate or B class, I put on 64 hours this season and I'll ride this bike again in '11 then buy something new for 2012.
Here's a sample of my maint. schedule :
Sept 25/10 Cleaned air filter @ 48.2 hours
Sept 25/10 Lubed clutch cable
Sept 25/10 Dunlop D745 rear off (9.7 hours) and Bridgesone M604 on
Sept 26/10 Raced in Larimore ND 0.8 hours
Sept 26/10 Bridgestone M604 off (0.8 hours) and Dunlop D745 (9.7 hours) back on @ 49 hours.
Sept 30/10 Fork oil (both chambers) and shock fluid replaced @ 50.5 hours (19.7 hrs on fluid)
Sept 30/10 Cleaned air filter @ 50.5 hours
Oct 1/10 Linkage bearings cleaned/re-greased 50.5 hours (22.8 hours between)
Oct 7/10 Engine oil/filter changed @ 52.9 hours (7 hours) Amsoil MCF
Oct 7/10 Cleaned air filter @ 52.9 hours - filter skin on
Oct 16/10 Removed filter skin @ 57.3 hours
Oct 16/10 Dunlop D745 off (18 hours) and Bridgestone M604 (0.8 hours) on @ 57.3 hrs
Oct 17/10 Cleaned air filter @ 58.9 hours - filter skin on
Oct 22/10 Filter skin off @ 60.9 hours
Oct 22/10 Engine oil/filter changed @ 59.9 hours (7 hours) Amsoil MCF
Oct 22/10 New NGK spark plug @ 60.9 hours
Oct 22/10 New OEM cam chain @ 60.9 hours
Oct 22/10 Lubed clutch cable and new EBC clutch springs @ 60.9 hours
Oct 23/10 Cleaned air filter @ 63.0 hours
  • skull1971
Posted December 28, 2010 - 05:34 PM
So,, I'm an old Suzuki guy, had several thumpers, DR's, QuadSport, and street bikes. We NEVER changed cam chains!! So are the cam chains in the early to mid 80's better than ones we get today? The 1985 Quad we wore it out, split the cases, rebuilt it,, wore it out again, rebuilt it, and rode it some more, and never replaced the cam chain. If I had a guess it had 5000 hours on it or more. So what's the deal?
  • mywifefarts
Posted December 28, 2010 - 06:25 PM
Awesome, Thanks!
  • mywifefarts
Posted December 28, 2010 - 06:26 PM
More RPM?
  • crf450319
Posted December 28, 2010 - 06:43 PM
Let's keep in mind that the OEM cam chain is $17.36, a Pro-X cam chain for the same bike is $64. I'm a firm believer in "you get what you pay for", and for less than $18 I'm not going to risk completely destroying my engine for such an easy/cheap fix. I'll run the OEM cam chains for 55 hours max., no more. If you have more faith in them than I do, :excuseme:
I should mention that I couldn't find anything on the internet as far as which cam chain (OEM vs aftermarket) wears better/longer, tensile stregnths etc.
  • Gunner354
Posted December 28, 2010 - 07:00 PM
The bike is ridden single track and motocross tracks by my son in law. He's a fast b rider.
We use Redline 10/40 motorcycle specific oil. Redline uses the best base stock known to date.
  • Hot  113 replies
  • On January 15, 2017
  • Hot  38 replies
  • Hot  50 replies
