Clutch Basket from 06 fit 03 WR450?
3 replies to this topic
  • dazzabb
Posted December 27, 2010 - 03:59 AM
Will an 06 clutch basket fit an 03?
Ordered an 06 by accident from e-bay and after checking the part numbers for 03 / 06 they are not the same!
Wondering if it will fit?
  • WR450FGreg
Posted December 30, 2010 - 11:40 AM
If it were me I would be checking the part number of the shaft it sits on to see if that's the same.
I'd then do the same for clutch plates.
I'd then, as a final check, have a close look at the diagram of it in each parts list. (Not exactly 100% reliable, but worth checking anyway).
If it looked the same in both diagrams then I'd reckon it probably would work.
Take the side cover off and try it!
  • MaxPower
Posted January 01, 2011 - 05:37 PM
[COLOR="Green"]I am not 100% but I think they are different . I think the gear has a different amount of teeth, I think its one tooth different .Maybe you could change the primary gear on the end of the crank to match.
You can sell it again on ebay if what I am saying turns out to be true
How much was it
  • dazzabb
Posted January 02, 2011 - 06:08 PM
I'm still waiting for it to arrive....
It was $75 on ebay.
