EFI & Yosh RS4
8 replies to this topic
  • Jeepentj
Posted December 24, 2010 - 10:27 AM
For those of you with the Yoshimura RS4 exhaust, what EFI mappings are you running? Initially I was running the Jay Marmont mapping but the pipe started to discolor (it's not Ti) so I went back to stock (all zeros). I've played around but haven't found anything I'm really happy with. So... what are you running?
  • Davey762
Posted December 24, 2010 - 03:38 PM
Been using this map for almost the entire time since having the pipe, really pulls harder. Can especially notice the difference when hill climbing.
"Setting for improved response"
"This setting is suited for a linear engine response to throttle work when riding on dirt with good traction or on high-load sand courses. This setting helps to achieve faster engine revving up through the rpm range for owners who want to ride more aggressively."
Fuel Injection (FI)
-2 -4 -4
-2 -4 -4
-2 -2 -2
Ignition (IG)
+3 +2 +2
+3 +3 +2
+3 +3 +3
  • Troutman
Posted December 24, 2010 - 09:34 PM
The first 5 inches or so of my YOSH stainless head pipe changed to purple and the remainder of the head pipe is a very light goldish color, is it not supposed to change color after you ride it? I thought that this was normal even for a stainless pipe. The bike runs perfect..
Posted December 24, 2010 - 09:55 PM
Of course it will change color. The pipe can heat to over 900 degrees. Stainless will turn dull and brownish with time. Ti will dull near the head, but stay a blue or yellow color for much longer.
  • rickallen124
Posted December 24, 2010 - 11:14 PM
Less hit or broad map is what I have been using depending on track conditions. The Marmont map is the next one I'll try.
  • Troutman
Posted December 25, 2010 - 11:50 AM
Thanks Grey, Jeepnjt it sounds like you should just run the Jay Marmot map that you like and not worry about the pipe color, its all natural and normal. :excuseme:
  • Jeepentj
Posted December 26, 2010 - 09:34 PM
I'm not so sure. I have the stainless RS4 and the first twelve inches of the pipe turned bluish - similar to what a Ti pipe looks like when it's hot. It's my understanding this occurs because of a lean condition (when this happens to a stainless pipe).
  • tech24
Posted December 27, 2010 - 05:08 AM
I think this is a myth, my pipe turns blue then brown after its cleaned and polished and my bike is definently not running lean
Posted December 27, 2010 - 06:44 AM
It happens because the exhaust gets hot, stainless or otherwise. The SS pipes on both my '06's are dark all the way to the midpipe.
  • Hot  47 replies
Motocross
  • Hot  491 replies
  • Hot  113 replies
  • 10 replies
