bent front end (uncle peanuts)
4 replies to this topic
  • yz250cranker
Posted December 16, 2010 - 02:01 PM
i have had the front tire off from a puncture i hit a rock and i think i bent the front end the bars wont aline straight with the bike unless tilted to the left i checked the triple clamps and from there i need a guru maybe bent triple clamps?
  • yz250cranker
Posted December 16, 2010 - 02:06 PM
Get the bike up on a stand (milk crate) just to get the weight off the front wheel.
Loosen the pinch bolts holding the fork tubes a bit, then stand in front of the bike and pinch the front wheel between your knees while you grab the bars and turn both ways until the front end straightens out.
Re-torque the pinch bolts to spec.
This usually fixes the prob'. Does it?
  • cowboyona426
Posted December 16, 2010 - 02:20 PM
You shouldn't need to loosen the pinch bolts on the triple clamps. What usually happens is the lower fork tubes twist a bit. Remove the tire, reinstall it (once you can get the axle back in) and before you tighten the pinch bolts on the axle take the bike off the stand, hold the front brake, and cycle the front suspension a few times. This should help to center the tire in the forks. Sometimes you need to smack the tire against a tree or the side of a building, but usually compressing the suspension a few times does the trick.
  • myoung
Posted December 16, 2010 - 02:26 PM
Geeezz, how big of a rock did you hit? After a certain point, they're called boulders. lol!!
It sounds like something moved in the clamps. How did you check them?
  • yz250cranker
Posted December 17, 2010 - 12:00 AM
boulder rock i dissassembled for repair
  • On January 15, 2017
  • Hot  36 replies
  • Hot  38 replies
  • Hot  113 replies
  • Hot  47 replies
