water pump seal gone already?
6 replies to this topic
  • dakotabo
Posted December 16, 2010 - 01:16 PM
09 Wr 450, I would be lucky to have 10 to 12 hours on the bike. I bought it new but haven't had much time at all to ride over the season due to work. I did however make sure it was started and taken for a short ride from time to time up and down the street. Today when I started it as usual, after 2 or 3 minutes of running i noticed some antifreeze on the ground under it. I took the skid plate off and noticed it was leaking out of the weep hole from the water pump. I let it run a little longer, and it stopped. Now it has been cold out here, could it just be from things contracting because of the weather and then just warming up?
  • dakotabo
Posted December 16, 2010 - 02:57 PM
anybody?
  • djv5
Posted December 16, 2010 - 03:42 PM
They all do it, especially when cold. As the bike warms up, the drip stops.
Replace the waterpump impellar shaft seals to cure it.
  • tribalbc
Posted December 16, 2010 - 06:42 PM
Good chance it's just the seal shrinkage from the cold. I've had it on various seals and orings and the leak disappears when it's warmer.
f you own your bike long enough though you will be replacing the seals/ waterpump shaft one day. One of the only weak oints with this engine...
  • Flagstaff
Posted December 16, 2010 - 08:02 PM
My experience on a '06 will slowly get worse. Not time to panic but keep an eye on it. Irecall alot of info on this forum when Ihad my problem. Do a search.
  • dakotabo
Posted December 16, 2010 - 08:37 PM
I did a search, but just can't believe being so little run time that it would leak so soon!
  • Flagstaff
Posted December 16, 2010 - 08:45 PM
Agree, mine had more time, but not alot of time.
