WR 450 compression test
3 replies to this topic
  • hampsterracing
Posted December 15, 2010 - 01:29 PM
Is it possible to do a compression test on the 450 motor with the auto decompressor ?
if so what readings would you expect.
cheers
Roger
  • SXP
Posted December 15, 2010 - 03:15 PM
No, you can't - as you stated the AD mechanism nixes that. What you are after is a leak-down test:thumbsup:
  • GCannon
Posted December 16, 2010 - 11:49 AM
To perform the leak test (provided you have the equipment)
You will need to remove the valve cover and manipulate the Auto Decomp weight in order to release the exhaust valve for testing.
  • Flagstaff
Posted December 16, 2010 - 08:05 PM
I wondered about this also, thanks for the question and info.
