yz426f only wants to start a little after top end rebuild
24 replies to this topic
Posted December 14, 2010 - 06:23 PM
#21
YZF's usually widen. Honda's tighten.
Actually, YZF's hardly move. Seating after break-in, they usually widen.
I've never once seen one widen unless the cam seized and damaged the cap. Any "settling" that sometimes does occur, and all normal wear results in the valve moving up into the seat, thus closing up the clearances.
  • shibby-rider
Posted December 14, 2010 - 09:38 PM
#22
speaking of break in is 2 tanks of gas good?
Posted December 14, 2010 - 11:45 PM
#23
An hour should be adequate.
  • shibby-rider
Posted December 15, 2010 - 10:20 AM
#24
Ok thank you very much!
  • slodog
Posted December 24, 2010 - 07:09 PM
#25
Both my 09 YZ450F's were .001" too tight nearly all around after between 2-5 hours of operation. Checking them again after 15 hours, no change. It was only after 45 hours on both bikes that the clearances moved back into a wider spec.
Could be that of carbon build up. Though I'm not sure, only know that they were both too tight and needed slightly smaller shims at 15 hours. I then had to return them to the original shims after 45 hours.
BTW, my bikes have never shown any signs of wear on any of the journals, cam lobes, or buckets. Also I remove the head and jug every 30 hours to inspect and measure the rings always reusing the original OEM base, head and exhaust crush gasket without ever having any issues. I currently have over 300 hours combined on both bikes.
