2004 Acerbis 3.3 gallon - which radiator gaurds?
2 replies to this topic
  • KGSloan
Posted December 08, 2010 - 09:17 AM
Hey guys,
I've got a few parts that need to be ordered/repaired after last weekends first adventure on the WR....I will have to send my left radiator off to Mylers for repair and replace the stock "gaurds" with something that offers actual protection to the radiators.
I have done some research on here and I am going to go with the Unabiker gaurds. At the same time I do this I would like to add the Acerbis 3.3 gallon tank, which uses the 'YZ' shrouds. So, which gaurds to I purchase from Unabiker to fit with the Acerbis tank? The WR or the YZ gaurds for a 2004?
Thanks!
  • TLRam1
Posted December 12, 2010 - 11:16 PM
Hey guys,
Thanks!
Already did the research, the numbers and shrouds from the bikes you could use are. I used the same Acerbis tank but used factory Yamaha Shrouds.
Any of the below are the same and will fit, graphics could be different buying used.
05 WR Shrouds
LH 5TA-21730-00-00
RH 5TA-21740-00-00
Fits
05/06 - WR250F
05/06 – WR450F
03/04/05 – YZ250F
03/04/05 – YZ450F
  • unabiker
Posted December 15, 2010 - 07:24 AM
You will need to use the WR450F rad guards. The radiator on the 03-04 WR450F is 10mm wider than the 03-05 YZ450F.
