bronc3 said:
You can run the coil springs in the three shoe clutch if you desire to do so. Newer M/As come with a three shoe clutch and the "green" coil springs. This makes the clutch act "PW-ish".
No, he well beyond the PW even with basic mods (K&N filter, boyseen reeds, jetting, 70 main) still has it pinned and was getting bounced off by the
suspension... well lack of it:smirk:
bronc3 said:
If you stay with the bellevue spring washers, make sure your spring bolts aren't grooved up. Look inside the clutch shoe recess for wear grooves from the washers as well. Deep grooves won't allow the spring washers to move smoothly as the clutch engages and disengages, kind of like a grooved up basket on a big bike.
did SS washers off ebay, made in USA and high precision. Not sure what brand but they did look high quality. Marks are easily visible on the collar, a good mm or so into the material, could that be my engagement trouble? Again the rear wheel never moved at WOT. Will buy new bolts and spacers either way, could the damaged ones ruin my new washer stacks?
bronc3 said:
Sounds like you already know you can shim the shoe closer to the drum to adjust the clearance ( 1 - 2 mm I think) to compensate for wear, but if you like you can shim the spring washers tighter as well to raise the engagment point too.
If you could get that actual number I would be so appreciative:worthy: I was only asking for the ID so I could get a strong indication of what shim thickness I need for this. Don't need higher engagement rpm, I need lower. I don't want the bike pegged just to start up, he will get scared off or hurt. I want a good linear hit for him, so he can climb up hills without bog, get her bucking yet still have control for tight areas etc.
bronc3 said:
As long as your drum is not severely grooved, it will work fairly well for casual use. If you wind up rebuilding, the "red" shoes have a different face design that doesn't groove up clutch drums.
I have seen those, I don't want to buy a new clutch because the drum is shot and it would ruin the new clutch. I don't want to buy a new drum because (they are over $200) and the old one does not fit the the 3 shoe, it is to shallow for the clutch depth and to big for the clutch diameter. On top of all this the
microfiche shows that the original parts both clutch and drum have been changed to a new one post 01 but does not tell us to what, not even sure if the new superceeded part is a 2 shoe clutch. He found out that the drum was changed in 01 and is the stock part #. Spoke to my dealer and he is going to contact KTM for me to know what is going on.
By the way to anybody looking for help with their older KTMs, this is your guy, ask for him by name though, he is IMHO exceeded every other person I have dealt with. Andy is my parts dealer(unless ebay is much cheeper:smirk:)
Big thanks to Andy at North County Yamaha in San Marcos CA. They are authorized KTM dealers, regular pricing on parts but he has spent hours helping with a mixup error (on KTM's behalf) for a $2 part:thumbsup: Very nice, if he doesn't know, he will get you an
answer and keep you posted until he does get questions/problems resolved:banana:
