WR400... what to expect from a 13.5:1 piston?? Both performance and work wise!
15 replies to this topic
  • Shred Jesse
Posted December 06, 2010 - 03:31 PM
Hey everyone,
Looking to majorly overhaul my WR400 this winter. I guess it's not as much of an overhaul, as it is addressing long neglected maintenance on the beast. ALL of the bearings are toast, nothings been replaced on it ever, and it's a constant work in progress. The good news with that though is I'm already really happy with this bike, and it's only going to get better! WOOHOO!
So one thing I'm considering doing is replacing the piston. Might as well just to be sure, I'd hate to have it slip and destroy the engine. Considering it's $150, and not all that impossible to replace, I may as well.
Now I notice pistons for my bike come in two compression settings. The standard 12.5:1, and the high compression 13.5:1.
Were I to switch to 13.5:1, what should I expect in the following areas:
-Will I need to re-jet?
-Will this make the motor less reliable than the standard 12.5:1?
-Will this affect the accelerator pump settings?
-How will this affect kick starting?
-How will this affect power?
-Are there any factors I am not considering?
Thanks in advance to those who share their experience on the topic.
  • spokexx
Posted December 06, 2010 - 08:23 PM
ive only been a WR owner since last saturday, but ive always known that raising compression will make the engine run hotter and youll probably have to run it only on race gas when you get up to 13.5:1. How much is a 5 gallon can of VP now? $50??
Sure it will make more power but you might have to rebuild it more often, but im not sure on these WR engines. My 1989 XT350 has 23,000+ miles on it and ive never cracked it open. It makes a measly 27hp... i think... but its always ran perfect and reliable. I believe it's compression ratio is 9:1.
Your bike has made it this long in stock trim, if you keep it that way it will last long again. But if you want more power, ive always had good results with WebCams camshafts.
  • The Captain
Posted December 06, 2010 - 08:38 PM
Nope.
Anything up to and including 13.5/1 is fine for pump 93 octane.
  • spokexx
Posted December 06, 2010 - 08:42 PM
really??? well thats good to know :thumbsup: I stand corrected.
  • tribalbc
Posted December 06, 2010 - 09:09 PM
Hey everyone,
-Will I need to re-jet? probably not, maybe one step leaner on the pilot
-Will this make the motor less reliable than the standard 12.5:1? No as long as there's no detonation
-Will this affect the accelerator pump settings? no
-How will this affect kick starting? A little harder to kick
-How will this affect power? Good gains on the bottom to mid
I had a JE 13.5-1 in my 07 for the last season (150hrs) of racing and riding. Good gains (though I did do it the same time I put YZ cams in) 93 and sometimes 91 pump gas no problem. When I pulled my piston this fall the rings and piston still looked new and were well in spec :thumbsup:
  • tribalbc
Posted December 06, 2010 - 09:11 PM
Aggresive cams are much harder on a motors longetivity than a HC piston.
  • Birdy426
Posted December 06, 2010 - 10:08 PM
Starting is a bit harder, rev is a bit slower, power is A LOT better!
  • Shred Jesse
Posted December 07, 2010 - 12:31 PM
Interesting about the slower reving. I wouldn't have expected that! How much harder is kickstarting?
I find the process a breeze right now on my WR400, but I've yet to run it on really really hot days at a crazy pace. It does have hotstart though!
  • Shred Jesse
Posted December 07, 2010 - 12:33 PM
Did it require rejetting when going with the new piston?
  • tribalbc
Posted December 07, 2010 - 12:55 PM
No but read my answers in your quote on my previous post
  • Shred Jesse
Posted December 07, 2010 - 08:03 PM
Oh, right I missed those! Okay awesome. I think I'll go ahead with this!
  • Birdy426
Posted December 07, 2010 - 08:29 PM
By harder starting, I just meant you have to kick with more authority as you are compressing more stuff...my 444 still starts first kick, most of the time.
Slower revving is because on the compression stroke, you have more resistance to motion...
  • Shred Jesse
Posted December 07, 2010 - 09:41 PM
Interesting... how does that affect low end log? If there's more resistance to movement, I imagine low end lug would be reduced...
  • Birdy426
Posted December 07, 2010 - 10:40 PM
No...low end lug is actually better cuz you're getting more thump from each power stroke.
  • Shred Jesse
Posted December 08, 2010 - 12:11 AM
Ohhhh, okay!
It sounds to me like this is the best way to just add some pep to the bike without altering it's power characteristics too much. Thus far I love it's performance offroad :thumbsup:
  • Birdy426
Posted December 08, 2010 - 08:58 PM
You'll love it more with more compression!
