426 carb issues
11 replies to this topic
  • 426beastlover
Posted December 06, 2010 - 02:46 PM
i just rebuilt my carb on my 426 because it was so dam hard to start i found that one of the jets was clogged so i cleaned it out and found that the bike starts up no problem now. i issue that im having is i let the bike warm up on idle, and when i give it some gas it revs up and dose not want to come back down. i can shut the bike off and restart it and it will idle fine till i give it some gas then it just stays up there. i need some help and suggestions would help.. thanks...
Posted December 06, 2010 - 02:56 PM
Be sure the hot start closes all the way. Then set up the pilot screw according to this procedure:
http://www.thumperfa.../jetting.htm#PJ
If the idle still hangs, read this:
http://www.thumperta...ad.php?t=327405
Still hanging? Check your valve clearance.
  • 426beastlover
Posted December 06, 2010 - 03:13 PM
thanks the next thing im going to do to the bike is the cam swap and have the valves checked out at the same time thanks for the reply
  • 426beastlover
Posted December 06, 2010 - 03:14 PM
the pilot screw is on the bottom of the crab right?
  • c_dasilva127
Posted December 06, 2010 - 03:19 PM
Yes the fuel screw is on the bottom of the carb. In for leaner, out for richer
  • 426beastlover
Posted December 06, 2010 - 03:22 PM
go it and the 426 is 1 1/2 turns out right
  • c_dasilva127
Posted December 06, 2010 - 03:25 PM
"seems like the most common jetting issue that comes up are pilot circuit related.the following is a sure method to choose the needed changes.
with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
this should happen between 1 and 2.5 turns on a fcr carb and 1 and 3 turns on a cv.
if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
choose the appropriate size and retest."
Posted December 06, 2010 - 03:34 PM
Maybe. Read the links I posted.
  • Dave102429
Posted December 06, 2010 - 03:41 PM
Did you install the Needle Valve in the correct orientation? It's that plate thingy on the front of the slide. The hole goes on the bottom. See part #11 http://www.apachemot...=2001&fveh=1038
I installed that upside down once on my YZ426F and that caused a hanging idle.
Edited by Dave102429, December 06, 2010 - 03:42 PM.
F
  • 426beastlover
Posted December 06, 2010 - 03:50 PM
i dont think that i took all that off i just pulled the crab and cleaned the jets. but i will check that and thanks every on the info i got i should be able to figure it out and thanks for the links they will help a lot tanks again
  • 426beastlover
Posted December 06, 2010 - 03:51 PM
but i will check tomorrow
  • 426beastlover
Posted December 10, 2010 - 09:42 AM
well i just did everything that everyone suggested to no avail. the bike it doing the same thing i let it warm up and the idle is nice and strong but the moment i give it gas the bike revs up and never drops i did change the oil and found some metal shavings in the oil filter so of to the shop the bike goes
  • Hot  36 replies
  • 9 replies
