Dumbfounded over quiet "CAP" performance!
10 replies to this topic
  • FTD
Posted July 14, 2003 - 06:00 AM
Can anyone explain to me why my bike is so much faster... in the mountains... after puting on the quiet cap. I was under the impression that the loud caps made the bike flow better and produce more power. It blows me away. I posted in "Loud Pipes II" that the thing has never pulled that hard. I have never had the bike almost rip the grips out of my hands... and it did last week... on dusty, loose trails. Is it pulling harder because it is a smoother power delivery therefore now spinning the tire as much? :)
Hoss
  • endurodog
Posted July 14, 2003 - 06:06 AM
2 thoughts, it could be because your jetting was off, i.e. to lean before. By putting the cap on it you richened it up and brought the bike alive.
2nd thought is that it did smooth the power out and made it easier for you to ride, matched your style to the bikes lowered output.
  • John_Lorenz
Posted July 14, 2003 - 06:37 AM
Another thought is this. The pipe is a bit more restrictive, This in turn can give a higher boost at low end (aka Grunt) but take away from top.
Funny thing about Air Flow dynamics :)
  • captain_S
Posted July 14, 2003 - 12:32 PM
The more flowing the pipe the more top end the power.taking out the retriction will soften the lower-to mid range pull,u would need to modify the intake side if you modify the exhast side,open exhaust needs more fuel to keep the power going up in a smooth curve(strong pull) unless it was over rich to begin,the combination of insert fuel and back pressure from pipe restriction has brought the power back to a stronger curve(strong pull)just where YOU use the power!,less back presure lets the motor rev faster and can make it go flat if the intake is not keeping up(i think!),yeah thats it :)
  • Gadsen
Posted July 14, 2003 - 04:35 PM
Can anyone explain to me why my bike is so much faster... in the mountains... after puting on the quiet pipe...
What brand and model of pipe was it?
  • FTD
Posted July 15, 2003 - 04:45 AM
FMF Powercore 4 2
  • CISCO
Posted July 15, 2003 - 10:51 AM
FMF Powercore 4 2
Thats what you call a quiet pipe? You sure you dont mean a Q pipe? The PQ4 is not what Id call "quiet" :)
  • FTD
Posted July 15, 2003 - 10:56 AM
Whoa, whoa... I meant quiet "cap." :)
Hoss
  • CISCO
Posted July 15, 2003 - 06:15 PM
AHHHH...I missred. Is that the turndown tip style? I have that on my Q pipe. I noticed big bottom to low mid gain and a total loss of top end with a quieter pipe. I am now doing hotcams to make some of that up. Its nice being quiet... :)
  • FTD
Posted July 16, 2003 - 03:57 AM
Derummm... hot cams? :D Please explain...
Hoss
  • CISCO
Posted July 16, 2003 - 04:52 AM
Pro Flow makes a high performance cam shaft. If you run both intake and exhaust cams it really boosts the top end with a little loss on the bottom end (Im talking about a DRZ). If the bottom end loss is too bad Ill toss in a higher compression piston.
