06' YZ450F Crank Play
3 replies to this topic
  • bhsballer76
Posted November 30, 2010 - 02:56 PM
I was wondering how I would measure the side to side/ left to right play in the crank rod on my 2006 yz450f? I pulled the top end the other day and it had a little play at the very top of the rod..
Thanks
Posted November 30, 2010 - 03:46 PM
Look at page 2-7 in the '06 manual and read this:
http://www.thumperta...d.php?p=9795655
  • bhsballer76
Posted November 30, 2010 - 08:16 PM
do u have an 06 manual? my understanding is between .02-.04 inches? That would be measurement "F" correct?
Posted November 30, 2010 - 08:30 PM
Can you spell "you"? You could do that much if you want help from someone, eh?
"F" tells you the clearance at the rod bearing. This is to be measured by rocking the rod side to side WITHOUT letting it slide back and forth on the crank pin. And yes, that's .010 - .020". Letting it slide would include the side clearance ("A") and exaggerate the reading.
  • Hot  36 replies
  • Hot  30 replies
  • Hot  113 replies
