Best Triple Clamp
11 replies to this topic
  • yz_ripper
Posted November 29, 2010 - 12:24 PM
Hi All, i had to replace my neck bearings and while i had the clamp removed i figured i'd invest in a new one (i have some extra cash), mainly to eliminate some arm pump i get after a few laps around the track. The bike is a 2008 YZ 450, im currently looking at RG3 clamps, any suggestions or feedback would be great!
thanks!
Posted November 29, 2010 - 12:53 PM
Are you looking to change the handling characteristics, or do you just want rubber/isolated bar clamps?
  • aedwards07
Posted November 29, 2010 - 04:11 PM
Im a huge fan of the X-trig clamps.Really you cant go wrong with them or RG3 clamps.
  • HRC
Posted November 30, 2010 - 05:19 AM
I would go for the Xtrig clamps ! Adjustable offset, rubber mounts for the bar. Looks nice !
  • ectm3
Posted November 30, 2010 - 07:59 AM
if you dont mind extra weight id go with the rg3 clamps.The best setup for weight and bang for you buck are the applied clamps(if your looking for a top and bottom setup with the offset). If your only looking for a top clamp id go withthe rg3.You could also try a stabilizer(Gpr or scotts)if your looking to get rid of arm pump a good stabilizer will work alot better than a tripple clamp setup.You can also buy tripple clamp setups from gpr or scotts that will give you the offset your looking for.
  • bg10459
Posted December 01, 2010 - 04:09 PM
I've got nothing bad to say about the RG3 clamp on my YZ. I like the rubber mount clamp better than the solid mount BRP I had before. I also think I like 7/8 Renthals better than the Twinwalls I'm using.
  • BBrown626
Posted December 01, 2010 - 04:47 PM
thanks!
Spend the money on some time with a coach. The arm pump is probably due to riding posture.
  • myoung
Posted December 01, 2010 - 11:21 PM
I don't get arm pump, but when I bought my '09, after just one ride I noticed some fatigue in my arms going from the RG3's on my 426 to the solid mount on the 450. I put the RG3's on the 450 and problem solved. They really do make a difference. Even if you didn't go with the RG3's, go with something isolated.
  • HRC
Posted December 02, 2010 - 12:26 AM
One thing I don´t understand about Yamaha´s mx bikes, Why don´t ther fit rubbermounted bars on stock bikes ?
  • myoung
Posted December 02, 2010 - 01:06 AM
I think they did for a few years, then went back to solid in '09 so they could make the bar position adjustable.
Posted December 02, 2010 - 07:27 AM
If they ever had rubber mounted bars, it hasn't been in the last 12 years. They were cast into the triple clamp up until '06, but the '06-'08 models bolted into holes in the clamp without isolators. They were reversible so you could move the bars back 10mm if you wanted, but that was it.
  • myoung
Posted December 02, 2010 - 08:45 AM
Oh, OK, for some reason I thought they went to that set up with isolators. My bad, carry on. :thumbsup:
