Shaving/ Filling Piston Ring
3 replies to this topic
  • bhsballer76
Posted November 25, 2010 - 06:39 PM
I was wondering how harmful it would be to shave the end of a piston ring with a file?
When recenlty installing the cylinder on my yz450f, I accidentally snagged the tip of a piston ring. This caused it to bend down slightly. I top end back on bt have not yet ran the bike...
I want to ride this weekend and was wondering if i could pull the top end and just shave the end of the ring to take the sharpness/ jagged edge off of it..
I dont minf replacing the rings, but wont be able to get a set in before this weekend...
Any thought? I know i shouldnt do it, but is it that big i a deal?
Posted November 26, 2010 - 07:25 AM
If you don't mind buying a new cylinder and piston (or worse), go ahead. Otherwise, absolutely do not try to repair the damaged oil ring.
  • bhsballer76
Posted November 26, 2010 - 01:01 PM
enough said..why did u assume it was an oil ring?
Posted November 26, 2010 - 03:51 PM
They are the only ones of which you can bend the corners over.
  • Hot  36 replies
  • Hot  33 replies
  • Hot  79 replies
