Forks have little play
4 replies to this topic
  • czechalien
Posted November 23, 2010 - 03:43 PM
2009 YZ450F, when I take off the front tire and hold the lower part of the fork (shiny part) and move it side to side or back and forth, there's a small play.
I always thought you should not be able to wiggle it at all. it is small amount, that it moves not much.
Well, my question is, is it normal?
  • brentn
Posted November 23, 2010 - 04:27 PM
I can't remember... The inner and outer bushing on the inner and outer fork tubes are supposed to prevent excessive play for a fork tube. If they are worn then you'll have a couple of problems
-bits of teflon from the bushing's entering the the lower shim stack
-Seal life is shortened because of excessive play which can cause excessive wear to the seal.
-If the seal is blown then you'll have even more dirt entering the system.
  • czechalien
Posted November 23, 2010 - 04:38 PM
I just replaced both bushings and the amount of play is the same. I have 90 hours on these forks since brand new.
Posted November 23, 2010 - 04:39 PM
The play you see at the end of the fork like that is about 8 times the actual clearance in the two bushings, assuming they have equal clearance. When fully extended, the upper and lower bushings are only about 3-4" apart, which lessens their control over the axle lugs by simple geometry. Since fork bushings must have clearance, "some" play is unavoidable.
  • czechalien
Posted November 23, 2010 - 04:48 PM
thank you very much guys.
I replaced bushing anyway since the coating on them was 50% gone.
  • 9 replies
  • 0 replies
