Just bought 06' 450F: Very Converned over Engine Noise
23 replies to this topic
  • bhsballer76
Posted November 21, 2010 - 03:43 PM
I just bought a 2006 YZ450F. I have been wanting one for a while and thought I found a good deal. Last week I bought a 2006 KX 450F because I couldnt find a yamaha in good shape untill this weekend.
So I get the YZ home today and I notice how noisy it it. I mean, its really concerning me. I then crank up the KX and it seems to have 4 stroke engine noise to it.
I am going to pull the top ends off both bikes tommorow. IS THERE ANYTHING I CAN LOOK FOR TO REASSURE ME THE BIKE IS OK?
play in the crank? valve clearances? cam chain tension?
Also, would the thickness of the valve shims indicate how much life is left in the valves??
I got the bike from a second owner who said he put 65 hrs on it while the first owner put 10 hrs on it. The second owner said he pulled the cylinder at 40 hrs and noticed a slight scratch on the cylinder wall and so he replaced both the cylinder and piston at 40 hrs. He said valves have never had to been adjusted.
GUYS....PLEASE HELP..the yz looks like it was maintained much better than the kx, but the kx seems to be much quieiter and smoother in terms of engine noise...I cant afford to keep both bikes, but the one I keep I plan on having for at least 3 years.. I cant afford to keep the Yami if its a ticking time bomb..
Here are videos of both.. The first it the yz.. You can hear the knocking sound much louder than on the kx, which is the second video..
http://s146.photobuc...nt=108_2312.mp4
http://s146.photobuc...nt=108_2313.mp4
  • kyle450rider
Posted November 21, 2010 - 08:01 PM
I have a 2007 with 38hrs on it. My bike is noisy in the top end. It concerned me but from what I've read on TT some of the yamaha's are just like that.
  • bhsballer76
Posted November 21, 2010 - 08:25 PM
As noisy as mine??lol..
  • Mr. Neutron
Posted November 21, 2010 - 08:28 PM
bhsballer76,
I've read on here that bikes with an aftermarket skid plate tend to sound much noiser than they would without one. Try taking yours off, if it's an aftermarket, or a bigger offroad one, and listen if it's quieter..... There's actually quite a few threads here on that very subject. I guess when Yamaha went with the aluminum frame, the bigger/heavier duty aftermarket skid plates made the engine noise louder..... :p I'd sure look into this before I tear into the top end.....
I'm about to find out first hand the difference in noise sometime soon; I just got a ThumperTalk skid plate to put on my '06. I plan to put some sorta rubber insulator between the frame & the skid plate, in an effort to help keep it quiet.
Jimmie
  • bhsballer76
Posted November 21, 2010 - 08:32 PM
bhsballer76,
Jimmie
Thanks. I will def do that since it only takes a minute to do. Its not a huge skid plate, but it is a slightly larger than stock works connection skid plate.
  • gscx
Posted November 21, 2010 - 08:35 PM
They both sound the exact same to me. lol
  • bhsballer76
Posted November 21, 2010 - 08:42 PM
yea, its harder to tell in the videos. In person the yz is much more loud in the engine.
Posted November 21, 2010 - 09:27 PM
YZ450's are notoriously noisy. The first thing to do is to compare yours to another one. Most of them sound like the National School of Pipe Fitting.
  • gscx
Posted November 21, 2010 - 09:29 PM
whats causing it? Is the 2010 engine just as noisy?
Posted November 21, 2010 - 09:40 PM
A lot of the noise is generated by the backlash in the primary gears. They made a change in '08 to address this, but I don't know how successful that was.
  • tech24
Posted November 22, 2010 - 06:47 AM
My 2010 is considerable less noisey than my '04.
It sounds normal to me idle seems a little low too so I hear more engine than exhaust
  • Mikeb12
Posted November 22, 2010 - 09:07 AM
i have an 04 that i maintain meticulously that sounds about like that. I also think your idle is a bit low which amplifies the sounds but my first reaction to your video was that it sounds like a yz450 to me.
they do sound like they have rocks rolling around in the motor but i promise, there are no rocks (or marbles) in there. i checked. that being said, i understand your fear and only a look inside will tell the tale but do know, yz motors are noisy.
  • Steel Panther
Posted November 22, 2010 - 10:52 AM
my 09 sounds the same, it makes kind of a whirling noise at idle. Its been like that since the day I rolled it off the show room floor.
  • Ga426owner
Posted November 22, 2010 - 11:39 AM
Yzf sounds normal to me....
  • sacfelix
Posted November 22, 2010 - 12:20 PM
My 06YZ450 sounds the same way. I originally thought it was going to blow up after I put a skid plate on so I bought a can of rubber under coating and sprayed the inside of the skid plate.
  • dvn
Posted November 22, 2010 - 01:49 PM
+1 The skid plate definitely amplifies it. Line your frame rails where the skid plate contacts them with strips from an old inner tube. It helps.
Edited by dvn, November 22, 2010 - 03:24 PM.
  • davcon
Posted November 22, 2010 - 03:02 PM
Just went out to record. Mine is noisy too. 119 hours. Timing chain changed at 90 hrs. No other top end work done except valve adjustment. Well maintained and treated.
  • Troutman
Posted November 22, 2010 - 08:35 PM
My 06 was very noisy in the top end as well, very normal. That bike was as reliable as an XR 80.
  • bhsballer76
Posted November 22, 2010 - 09:11 PM
Hey, really appreciate the video. Really eases my mind . I pulled the tp end today and found a weisco piston and jug in mint condition. The guy i bought it from said he installed both at about 40 hrs.
  • jrny426
Posted November 23, 2010 - 10:01 AM
My 07 sound bad too but runs great no issues
  • On January 15, 2017
  • 5 replies
  • Hot  113 replies
  • 10 replies
