Latest Brain Fart
4 replies to this topic
  • L. Euler
Posted November 20, 2010 - 05:22 AM
So the drive gear for the odometer broke on my WR450. I removed the drive gear ordered a new one and in the mean time installed an axle spacer and left the meter cable disconnected so I could continue riding. The new drive gear arrived, I installed it and went to reconnect the cable. Soon discovered that the internal drive cable had completely slipped out of the outer sheath while riding. Now I'm waiting for a new odometer cable...doh!
  • Shred Jesse
Posted November 22, 2010 - 11:58 AM
What did you use for an axle spacer exactly?
I'm debating removing all of that stuff as I just really don't care :p
  • L. Euler
Posted November 22, 2010 - 07:13 PM
because the odometer gear was wrecked, I salvaged the spacer from the gear.
  • L. Euler
Posted November 23, 2010 - 04:31 AM
I would also add that right side secondary bearing seal is formed by the odometer gear assembly. I would not suggest riding without it unless you get a YZ front hub that has a recess for the secondary seal. You would also need a proper YZ spacer.
  • SoCA_DRZ
Posted November 23, 2010 - 08:46 AM
Flatland Racing makes an odo removal spacer:
http://www.flatlandr...ter Eliminators
