2010yz450 hop up
9 replies to this topic
  • Ron Hamp
Posted November 18, 2010 - 05:23 PM
We @ TUF have the engine kit ready for sale .The new yamaha engine responded to porting and the usual very good producing 60 hp and ove 37 #s torque.i had a x sx pro take it for a spin and said it was wy smoother and pulled much longer than the yzhe had ridden in the past.The tufracing.com sight is up and the kit can be purchased from the sight i was authorized to offer the first 5 kits @30% off if ron hamp is mentioned in the order .i will put up dyno graphs this week.
Posted November 18, 2010 - 05:33 PM
The new Yamaha engine responded to porting and the usual very good producing 60 hp and over 37 #s torque.
I knew it would in your hands. :p
  • brentn
Posted November 18, 2010 - 11:08 PM
How do your cams and porting compare to the GYTR ported head+cams?
Don't smack me in the face, I have a feeling your work is alot better but would like the details as I'm sure others would too!
  • Ron Hamp
Posted November 19, 2010 - 05:53 AM
The Bike as tested on the dyno lacks torque down low even though its very quick reving the engine seems to have light crank mass.the cams that i desighned are shorter than stock duration and and produce more bottom end as well as top end .the stock head has an abrupt short side and did not produce swirl paterns like mine the head starts out with 106ccs and with the work i did still ended up with 106cc and flowing consideably more air the gyt head is a cleaned up intake port with even more volume the exhaust port is hogged out pretty good reducing velocity even more.a good example of engine effincency is the fuel required to make power i am up t 5% leaned @the top from stock and have taken timing out and still maKING 60 HP AND OVER 37 POUNDS OF TORQUE.
  • fireball722
Posted November 19, 2010 - 05:56 AM
can you give us an idea of the price in detail thanks
  • SEOINAGE
Posted November 19, 2010 - 05:58 AM
go to their website and look at products. Isn't the best to navigate but you can find it.
  • fireball722
Posted November 19, 2010 - 05:59 AM
also does the yamaha controller can do the job ! with your set up
  • Ron Hamp
Posted November 19, 2010 - 07:50 AM
I was quite concerned about that when i saw the limited avaiability of adjustment but after tuning with it and seeing a good AF ratio and and getting good power results im determined it will work great with our kit .
  • mrtuf
Posted November 19, 2010 - 10:34 AM
Just to let you know the website is not finished and it will change as we update it every day. The only people who even know its up are those who heard about it from Ron here on Thumper Talk. You can order on it now. In the spot for the coupon code just type in ronhamp and it will automatically give it to you the discount. Also if you have any suggestions on what you would like to see in a website like this let us know. Thanks TUF Racing
  • brentn
Posted November 19, 2010 - 11:24 AM
Do you offer a map for the power commander 5?
Also what air filter were you using? did you have to do the air box mod (drill little holes in the air ducts)?
  • 0 replies
  • Hot  50 replies
  • Hot  113 replies
  • Hot  30 replies
  • On January 15, 2017
