new to me 450
4 replies to this topic
  • lumpy790
Posted November 14, 2010 - 05:48 AM
Its far from new but......I picked up a 08 yz450f basket case that had the clutch basket shatter. Cases have been split and everything cleaned out. They included a good clutch they picked up on feebay. But the cylinder has a ring around the top where the piston was so worn it was rocking.
Is this cylinder wear a common thing on 450's? Will it run with it like it is or should I get a new one or replate?
Might need a stator too as someone must have thrown something in the box and chipped the coating. I will re-seal it with some epoxy 1st and see if it works before buying a new one.
  • crf450319
Posted November 14, 2010 - 07:39 AM
That cylinder is shot, you'll more than likely need to replace the piston/rings/pin as well. A new OEM cylinder is $238 from, so the old one isn't really worth re-plating.
Good luck !
  • kx250fnick
Posted November 14, 2010 - 08:09 AM
Yeah,that cylinder is toast,wear on 450's depends how you ride them,just like any other bike.
Posted November 14, 2010 - 08:34 AM
A new OEM cylinder is $238 ... so the old one isn't really worth re-plating.
OTOH, it would be a nice core for a 470 kit.
  • lumpy790
Posted November 15, 2010 - 06:43 AM
No big bore kit for me......staying stock. Probably going with OEM piston too.
  • Hot  33 replies
  • Hot  79 replies
  • Hot  57 replies
Need help by Goforaride
  • Hot  68 replies
