Is it ok to mix 87 and 91 octane gas in a two stroke?
43 replies to this topic
  • Premixer112
Posted November 13, 2010 - 05:18 PM
My brother and I are racing tomorrow and we are almost out of fuel so I went to the gas station to get some more. I usually get 87 unleaded, but I've read that it's better to get a higher octane gas, so I got 91. Well, I have a full tank in my bike right now and my brother has about a half to 3/4 full tank. My question is: at the races tomorrow, when it's time to put some gas in, is it all right to mix the 91 with my usual 87 that goes in there? Or should I just dump the gas that's in our tanks tonight? If it matters, I have a yz 250 and he has a kx 65.
  • SubTexel
Posted November 13, 2010 - 05:22 PM
And you don't get pinging with the 87 on either bike? You can mix them yes, but you really should be running 91.
  • trailmeisterjoe
Posted November 13, 2010 - 05:37 PM
yep....91 and NEVER the 87.
Joe
  • Premixer112
Posted November 13, 2010 - 06:00 PM
Well damn, I've been using 87 since we got our bikes! Which was about 4 months ago.
  • brentn
Posted November 13, 2010 - 06:03 PM
What elevation are you at?
Some elevations will let you get away with running lower than 91 than others. The engine was designed to run on 91 (don't use anything higher, performance will drop), and will usually start to ping if you use anything lower.
  • Premixer112
Posted November 13, 2010 - 06:09 PM
I think it's around 500 ft.
  • OLHILLBILLY
Posted November 13, 2010 - 06:47 PM
YZ250, I'd be running 91 in it no matter the elevation. I even use 91 in my KDX. Cheap insurance IMO.
  • rotordawg
Posted November 13, 2010 - 06:54 PM
When you buy mid grade it is just a combination of low octane and high. So if you mixed a gallon of 87 with a gallon of 93 you would end up with about 90. Most modern gas stations have a mixer before it comes out of the nozzle. No harm in mixing it at all. Here in New England its all unleaded. All of the MX bikes today have high compression engines that prefer higher octane. But in a pinch I would use lower octane, especially if it meant pushing or riding, LOL
  • SubTexel
Posted November 13, 2010 - 07:11 PM
Geez, not this higher octane causing a loss of performance.
Using a higher octane will not decrease performance. It will also NOT increase performance unless you are jetted for it and running modified motor (increased compression, etc...). All you will do is lose money, but not performance.
(I've dyno'd quite a bit of my cars with 110, 100, 100LL, 93, etc... Guess what? Same numbers until I tune for the higher octane. Same principles follow with dirt bikes).
Anyhow OP, yeah run 91 / 93 (whatever is available to you) and nothing less.
  • Northwoodslivin
Posted November 13, 2010 - 07:19 PM
Interesting. I dont think high test should matter in a non high comp engine? I know that my YZ250F NEEDED high test due to it's high compression... But to answer your question, yes no problems mixing the two.
  • ekulb14
Posted November 13, 2010 - 07:24 PM
shoudnt make a difference i ran a a 125 at 5000 feet using 87 for years with no problems
  • SubTexel
Posted November 13, 2010 - 07:25 PM
All MX bikes require 91 or higher, 2 and 4 stroke, as do a lot of the off road models.
  • Northwoodslivin
ditto.
  • motomatt16
Posted November 13, 2010 - 08:08 PM
how many years ago were these years? way back when they werent all that high performance? or riding them like a old lady in trails?
  • ekulb14
Posted November 13, 2010 - 08:32 PM
humm not trying to bash you here but... idk about that
it was a 2000 yz, no mods and riding the piss out of it on motocross tracks.
  • downonmonday
Posted November 13, 2010 - 08:37 PM
Simple answer...yes, you'll be fine.
  • SubTexel
Posted November 13, 2010 - 08:39 PM
Umm not to point out the obvious, but look in your manual.
Also, look at your head and piston... Anyone I've known who's run 87 (usually when trying to save money) has damaged those two in very short order (buddy was a tight wad, ran 87 on his 06 KX250... guess what happened? Yup..). I've known guys who put around on their bikes with 87 but you can hear the bike pinging under any type of load. Not the brightest thing to do.
  • The Spanky
Posted November 13, 2010 - 08:49 PM
You're fighting a losing battle there, Texel, trying to convince people that using a higher octane fuel than necessary won't affect performance in any way. I've been trying to dispel that myth on here for years to no avail. It's such a widely believed myth that no amount of evidence or hard data will change most people's minds. People just don't seem to grasp the idea that octane rating has absolutely nothing to do with combustion temperatures, burn rate, or power production, it means nothing more than a fuel's resistance to detonation. But you can keep trying, maybe you'll have better luck than me. :p
  • Premixer112
Posted November 13, 2010 - 09:25 PM
Well, I ended up draining both our tanks and replaced them with the 91 because you guys got me all paranoid lol. I remember using 87 in my 04 CR85 all the time and never had any problems.. I never new this was such a big deal.
  • Grassman100
Posted November 13, 2010 - 09:35 PM
I use diesel in my YZ400F. Bitch to start though....:p:p
ATK 605 Enduro 1995 by atkharvy
ATK 605 Enduro 1995
  • 0 reviews
  • Hot  30 replies
BUILT CRF230 COMPRESSION! by DeaconJames
  • Hot  34 replies
ATK 125 CC 1973 by JESTER01
ATK 125 CC 1973
  • Last review by JESTER01
  • On January 21, 2017
  • Hot  38 replies
