2005 WR450 Wont Start
2 replies to this topic
  • SLOSupermoto
Posted November 11, 2010 - 07:22 AM
I have a CA plated WR that I would ride to school pretty regularly last year. When school got out for summer I let it sit for a bit too long and tried to go for a ride with my girl but had no luck firing it up.
Like an idiot I let it sit for even longer (started a new job and havent had time to tinker). So total sitting time is around 4-5 months now (I feel bad for neglecting it this long).
Last friday I pulled the carb (not completely, just off the boots at the airbox and head). I removed the fuel bowl and pulled all 3 jets, cleaned everything well, and slapped it back together. When i went to kick it over (e-start was removed by previous owner) I still had no luck. But when I sprayed some starting fluid into it it would fire up for a short time (running on fumes).
This tells me it's likely a fuel delivery problem?
What should my next course of action be? Any input would be greatly appreciated...
  • gsa102
Posted November 11, 2010 - 09:28 AM
Open the petcock and fuel drain screw to make sure the float isn't stuck shut. If stuck, clean and test it.
  • SLOSupermoto
Posted November 11, 2010 - 09:33 AM
I know the petcock is working, turned it on when the tank was off the bike. Ill try the drain screw on the bowl when I get home...
