floating brake
6 replies to this topic
  • luvmythumper
Posted March 05, 2001 - 11:26 AM
My 2001 has the front floating brake. I have noticed that it not only floats side to side, but will also "float" front to back. If I lock up the front brake and move the forks through their range, at some point the brake then gives and the front wheel rotates slightly. I checked this because I thought I was feeling a "notchiness" in the travel of the fork while under heavy braking. Anyone else experience this?
  • Guest_Guest_*
Posted March 05, 2001 - 03:20 PM
aaaaaaaaaahhhhhhhhhhhhh what?
  • luvmythumper
Posted March 06, 2001 - 09:48 AM
Is no one else experiencing this or is my description confusing? Any replies appreciated.
  • forloop
Posted March 06, 2001 - 10:17 PM
Yes, this is a nice feature. It reduces brake vibration. It was on both my KX's. It was not on my CR. I not sure it makes a big difference, but it's nice to have.
Rick
01 YZ426F #85 Vet C
  • Numpsy
Posted March 08, 2001 - 12:58 AM
A floating rotor will change its shape when hot.
If You try the same thing when the disc is hot the "float" should be a lot less!!
Numpsy
  • Boit
Posted March 08, 2001 - 01:29 AM
I thought the advantage of the floating system was less tendency to chatter under heavy braking....and a more "positive" feel under all braking conditions. Perhaps this system also requires more attention to maintenance as well to achieve this result?
  • forloop
Posted March 08, 2001 - 05:26 AM
When metel get s hot is does expand. But, On my KX's it always had the same amount of play. Even after a moto.
Boit:
You are correct it does reduce brake chatter. It also helps with grabby brakes. My KX had great front brakes, once I replaced the brake line and pads.
My 01 has a steller front brake. I am very impressed with it.
Rick
01 YZ426F #85 Vet C
  • On January 15, 2017
  • Hot  50 replies
  • 10 replies
