shift pin missing
1 reply to this topic
  • dalboy
Posted November 06, 2010 - 07:05 PM
my mates wr400 99 model would not shift out of 1st gear. so we pulled the clutch cover and found the pin holding the shift 2 lever (3XK-18122-00-00) missing. we found the shift lever roller (3XJ-18178-00-00) sitting in the case at the bottom but no pin. is this pin pressed into the part? and when we order a new one do you order the whole part as shown above, or can you order the pin seperately? also where is the pin likely to be? and is it common for it to fall out?
  • dalboy
Posted November 08, 2010 - 12:08 PM
no one else had this happen to them?
