carb comparison question
6 replies to this topic
  • mxmaddman
Posted November 03, 2010 - 05:37 PM
I have an 04 atv carb and a 07 dirt bike carb.
why does the 04 have some type of pilot diaphragm and the 07 doesn't?
Is the 04 supposed to have a hot start plunger? It just has a cap with nothing in the hot start hole.
Its running lean and i found a missing o ring in the diaphragm and no hot start plunger in the hole. I'm thinking its def the problem.
Posted November 03, 2010 - 06:27 PM
Yes, there's supposed to be a hot start plunger, and if it's missing, you'll have a huge air leak.
The pilot diaphragm is the same as that on a WR450 carb. It's part of the air cut valve, which is an element of the air injection system.
  • mxmaddman
Posted November 03, 2010 - 08:26 PM
I figured you would know if anyone would. Does the air valve need to be on the carb or can it be removed and blocked off?
Posted November 04, 2010 - 06:19 AM
It can be, but there is some compensation that must be made for its absence, and I'm not clear on the details. In a YZ450, air is fed to the pilot circuit through a single jet and passage. In a WR/YFZ, the air passage is forked, with one side bringing air in through a pilot air jet, and the other through the ACV. When the ACV is blocked off, the PAJ needs to be larger. See the WR450 forum for more info.
  • mxmaddman
Posted November 04, 2010 - 07:50 AM
OK thanks gray, Apparently you can flip the diaphragm and block the passage then add a larger paj or maybe smaller PJ.
I know the standard yz passage pulls from the paj, do you know where the second passage draws its air from?
Posted November 04, 2010 - 08:13 AM
I could trace it if I had a carb in my hands, but no, I don't.
  • mxmaddman
Posted November 04, 2010 - 02:46 PM
ok, thanks gray.. It looks like it might go up into the top of the carb above the slide...
  • Hot  113 replies
  • 5 replies
  • Hot  47 replies
  • On January 15, 2017
