general maintance 07450
7 replies to this topic
  • redswr
Posted October 27, 2010 - 04:22 PM
hey guys... i am getting ready to ride my bike down in the desert for the first time in about a year and i've never really taken it apart other than to put my mods on (all the free mods and some carb add ons). What should i look for as far as general wear and tare and what all should get lubed up? It's got about 3,000 miles on it and i checked that the vavles were still in spec about 200 miles ago.
  • Krannie McKranface
Posted October 27, 2010 - 05:26 PM
IMHO;
- re-grease everything: steering head, linkages, swingarm, hubs
- change fork and shock oil
- check spokes, rim runout
- check bolt tightness, being carefull not to use a over-sized torque wrench
- adjust valves (done)
  • SXP
Posted October 27, 2010 - 07:17 PM
Your chain and sprockets are probably close to the end of their life - you might want to check them.
  • YamaLink
Posted October 28, 2010 - 07:51 AM
Maybe replace the throttle and clutch cable or give them a good lubing and cleaning of the throttle tube/handlebar area.
  • 123BigcoopDawg576
Posted October 28, 2010 - 12:56 PM
Really...at 3000 miles? I put 100hrs on the stock chain and sprockets...maintenance, oiling and adjustment is key :excuseme:
  • SXP
Posted October 28, 2010 - 02:13 PM
Really!
Not sure what you mean - too much or too little? I have 3K on my bike and the stock chain/sprockets are definitely iffy:excuseme:
  • 123BigcoopDawg576
Posted October 28, 2010 - 08:41 PM
Really!
Yup! The only thing I do to my chain is keep it in spec per the manual and clean the chain with WD after a wash and then oil it before a ride!
  • KennyMc
Posted October 29, 2010 - 08:12 AM
I've replaced my sprockets with an Ironman set. My front sprocket went before the back but I replaced both at the same time. Don't know how many hours/miles. Doesn't really matter.
