Tusk Enduro light kit flasher question
5 replies to this topic
  • 2in2out
Posted October 27, 2010 - 02:13 PM
So I bought this barely used 2007 WR450 with a BD dual sport kit installed and Stator mod done. I don't care for the BD turn signals or headlight, but I'm diggin' the BD controls more than the Tusk kit.
Anyways, I attempted to install my LED Brakelight/Turn signals without success. Do I have to switch relays too?
William1, you always seem to have answers for these challenging questions. What say you?
  • William1
Posted October 27, 2010 - 02:30 PM
Tail light should work fine. Signals will require the appropriate electronic load independant flasher unit.
Am I correct in assuming you are retaining the BD switches, and wiring and just want to change out the lights, right?
  • 2in2out
Posted October 27, 2010 - 02:35 PM
Yes, I'll be retaining the BD switches. The taillight didn't work, and neither did the flashers. I'll attempt swapping flasher relays, but I was sure the taillight/brakelight would work. I really just want the low profile LED turn signals, and handguard LED signals.
  • 2in2out
Posted October 27, 2010 - 03:02 PM
I tried the Tusk relay. It works. Thanks.
  • JPMartin86
Posted October 27, 2010 - 04:07 PM
I have LED lights on my BD kit, the rear blinkers will turn on but not blink. The front blinkers will not work at all. If i connect the green, red, and orange wires together the front and rear blinkers will turn on but not blink. Is there a specific relay that i need to get my blinkers to work? Two prong? Three prong?
  • GCannon
Posted October 27, 2010 - 04:18 PM
You need a solid state or transistorized Flasher the LED signals will not create enough current (load) to activate the old Thermal style flasher. still has the same number of connections.
