Hinson?
2 replies to this topic
  • Guest_Guest_*
Posted February 28, 2001 - 04:40 PM
I know this has probably been asked, but can I just replace the basket with the Hinson or do I have to replace the whole setup?
  • dirtdad
Posted February 28, 2001 - 05:14 PM
While replacing the basket, inner hub and even the pressure plate with Hinson stuff will yield you uncompromising durability and improvement in the entire clutch; many members here have stated they experienced a big improvement with just changing out the basket only. I have the basket and inner hub from Hinson and will add the pressure plate later when I can afford it. The inner hub does have extra oiling holes and is machined, not die-cast so it spins truer. If your budjet does not allow though, the basket should be a sufficiant upgrade.
  • Guest_Guest_*
Posted March 01, 2001 - 04:26 PM
Thanks.
  • 10 replies
  • 5 replies
  • On January 15, 2017
  • Hot  38 replies
