How to make an aluminum frame and swing arm look like new again?
21 replies to this topic
  • chasemotox63
Posted 24 October 2010 - 10:31 PM
My aluminum frame and swingarm on my 09 kx250f seem to be getting scuffed up pretty easily and stained in some spots.
Are there any techniques or products you guys use to make them look clean and new again?
(I'm not looking to polish them, or make them mirrior like)
  • flattopwill
Posted 24 October 2010 - 10:49 PM
steel wool
  • MotoGuido
Posted 24 October 2010 - 10:52 PM
Wet sand it. Use a block to wrap the paper around when sanding the flat areas so you don't get low spots from your fingers.
Start with something like 400-500 then go to an 800 and from there you can decide how far to take it. 1000, 1500, 2000 will give you varying levels of smoothness. It will look nice and new again. The swing arm sticker will keep scratches from coming back.
  • honda88
Posted 25 October 2010 - 12:41 AM
Use a damp scotch Brite pad.
  • bikeride4fun
Posted 25 October 2010 - 04:13 AM
The Scotch Brite pad works the best......I went to my Napa store and got some of the purple ones that they use doing body work....works awesome.....
  • crazy_dave
Posted 25 October 2010 - 04:28 AM
MotoGuido said:
Wet sand it.
Start with something like 400-500 then go to an 800 and from there you can decide how far to take it. 1000, 1500, 2000 will give you varying levels of smoothness. .
Then use 0000 grade steal wool and AutoSal. It will look like chrome.
Edited by crazy_dave, 25 October 2010 - 04:57 AM.
  • scott508
Posted 25 October 2010 - 04:56 AM
Use 0000steel wool or a ScotchBrite pad and lubricate the surface with WD-40. This works great on swingarms, and even aluminum frames that have etching from being left outside. The WD-40 also gives the metal a bit of corrosion resistance so you should need to repeat the process less frequently after the first go.
  • tpars121
Posted 25 October 2010 - 07:44 AM
I use Brasso on a scotch brite pad and then rinse it down with WD-40 and wipe it clean.
  • KJ790
Posted 25 October 2010 - 07:48 AM
I've found SOS pads work great, just use it when you wash the bike. It takes 2 seconds and the frame looks new when you rinse it off.
  • slomojo
Posted 25 October 2010 - 08:03 AM
I just have the maid polish mine,I think she uses that frilly little apron!
  • Jrs Turn
Posted 25 October 2010 - 08:29 AM
^ :thumbsup:What he said. You said you don't want it polished so skip the 400, 600,1000 wet sanding stuff. 0000 Steel wool and WD40 will give a nice satin finish that won't stain or water spot.
  • john484
Posted 25 October 2010 - 09:20 AM
ride in the dunes!    seriously, it will have your bike shining, especially the aluminum.
  • Jim813
Posted 25 October 2010 - 09:22 AM
This is what I do and it works well:thumbsup:
  • MotoGuido
Posted 25 October 2010 - 08:18 PM
I use the 0000 steel wool to take off my boot marks but he was sounding like he had some deeper scratches. :excuseme:
  • mxmx0606yzf
Posted 26 October 2010 - 06:55 AM
scoth brite works pretty well
  • Jrs Turn
Posted 03 November 2010 - 09:23 AM
Nah, he was just saying he had some scuffing and staining.
  • plurpimpin
Posted 03 November 2010 - 10:43 AM
scotch brite pad works the best. just be sure to get the ones with soap in them
  • CRF150Rfreak
Posted 10 November 2010 - 05:02 PM
Using 3M scotchbright pads start with the red one lubricated with WD-40 then go to the gray one with WD-40 and finish it off with the yellow with no luby being gentle. BRAND NEW MAN!!!
  • chasemotox63
Posted 16 November 2010 - 11:30 AM
Thanks for all the input guys!
I ended up using the regular Scotch Brite pads and here's how she turned out:
They seemed to be a little rough, so I think I will use the lighter pads next time.
  • YHGEORGE
Posted 16 November 2010 - 12:49 PM
Interesting thread and how some gave answers to a question not asked.
