Ti Intake Valve ?
5 replies to this topic
  • nikdaqik_231
Posted October 22, 2010 - 02:39 PM
Just did my first valve adjustment on my o7 450. The center intake valve was tight, the rest ok. My ? is about the Ti valve itself.
My last bike was a Crf450, when I had a tight valve it wasn't worth adj..The hardened coating on the valve was gone and if adj would only last one ride. I have had soooo much better valve train life with the YZ. So, will the valve I adjusted last or is it time for new valves?
Only getting 70 hrs on the Crf450 Ti intake valves, glad those days are over!
  • Steel Panther
Posted October 22, 2010 - 03:32 PM
its a yamaha, dont worry about it :excuseme:
Posted October 22, 2010 - 04:13 PM
You'll know when you check it again in 4-5 more hours. If it's still where you set it, it's OK. If it's already moved tighter, not.
How tight was it?
  • nikdaqik_231
Posted October 22, 2010 - 05:09 PM
Zero clearance!
Posted October 23, 2010 - 07:42 AM
That doesn't sound good. Usually any time the valve moves more than 0.5mm, it spells trouble.
  • nikdaqik_231
Posted October 23, 2010 - 11:25 AM
Hopefully ride tomorrow, should be a good test for my questionable valve (???).
Older & YZer, Love that!!!
  • Hot  50 replies
  • Hot  36 replies
  • 10 replies
  • On January 15, 2017
  • 3 replies
