WR 08 ProTaper handlebar Spec ?
6 replies to this topic
  • dadspants
Posted October 22, 2010 - 05:48 AM
Hi all,
I am after a set original wr 08 Pro Taper (5xc2611-lo) Yamaha part no, (5xc-lo) printed on the bars. I have a 06 WR but love the feel of the bars on my friends 08 model. I know i will need the conversion kit and that will lift the bars slightly, but being 6ft2" i could do with the bars being lifted anyway.
Apparently the bars on the 08 model are only available from the manurfacturer as, Yamaha own the bend set? I have priced from Yam and they are not cheap so will not be getting them needless to say :excuseme:
I was wondering if any of your know what the same bend set is for the Pro Taper bar, i have read YZ-low ? Or if Renthal do the same bend set :smirk:
Any help welcome :lol:
  • jayh300
Posted October 22, 2010 - 06:43 AM
just did that to my 06 wr... these are a set of oe wr bars i bought off ebay with a set of protaper mounts on the stock wr top clamp.. the bolts are a little long, so i had to put one extra washer on them...
i never found the bend on the oe bars either..
  • dadspants
Posted October 22, 2010 - 07:08 AM
Thanks Mate,
So it's over to ebay to look out for a set..With regards to the mounts do you happen to know the part number, i like the look of them :excuseme:
Cheers
MArk.
  • jayh300
Posted October 22, 2010 - 07:35 AM
http://cgi.ebay.com/...lQ5fMerchandise
it was these... it says rubber mount, but it is solid to the top clamp..
  • dadspants
Posted October 23, 2010 - 12:41 AM
Many thanks, just need to find some bars now !
  • dadspants
Posted October 23, 2010 - 12:57 AM
Anyone else know what bars, are the same spec as the oem standard 08 Yam Pro Tapers? Maybe a Renthal equivalent....
Suggestions please :excuseme:
  • kawi380
Posted October 23, 2010 - 05:38 PM
I normally run only Renthal Fat Bars in the CR HI bend but the stock WR pro tapers measured almost exactly the same so I left them on the bike and have no complaints whatsoever.. I can't remember what was different but they were real similar.
