how to fix exhaust 03-05
2 replies to this topic
  • jarod17
Posted October 20, 2010 - 12:45 PM
I have a yz450 its an 03 problem is it has a small hole in header where heat shield bolted on. what is the best way to repair this, if any.
jerry
Posted October 20, 2010 - 01:06 PM
The stock header is light gauge titanium, and having the hole patched by welding a piece over it, the most obvious way of repairing it, is a job only for a very skilled TIG welder.
If you want the easiest, lowest cost means of fixing it ( I did not say pretty), you could take a piece of sheet metal, form it to the pipe, epoxy it on, and hold it in place with a hose clamp.
The easiest way to fix it neatly is to replace it with something used from eBay or the classifies here.
  • jarod17
Posted October 21, 2010 - 03:46 AM
thanks
