In need of PVC?
2 replies to this topic
  • Guest_Guest_*
Posted April 09, 2001 - 05:54 PM
Im going to the dunes in a couple weeks to air out the big bad boy. The stock springs were a tad on the soft side last time I went out there and thins time I would like to put some preload on them before I go. Not too much...but not too little. FYI Im 235 lbs.
Do I use washers? Or PVC? I have had people tell me to use both. If washers how many and how thick? If PVC how long should I cut it?
Thanks!
Darin from Missouri - 1999 WR 400F
Enduro Heaven
  • MN_Kevin
Posted April 09, 2001 - 11:33 PM
Darren,
I have used washers in the past. The O.D. was just short of the forks I.D.
For lots of slop, I would go with a washer/PVC combo, myself.
Do you need that much preload??
  • Guest_Guest_*
Posted April 10, 2001 - 03:50 AM
Well, my forks are pretty soft. Not to mention Im low on fork fluid because the seals are leaking. (why replace them before I go ride in the sand?)
Should I add about 1" of washers and try that and see how it feels? (not to mention adding some fluid) I dont want to over-do it.
Enduro Heaven
