Ford 4.6 common problems?
Started by
crider400
, Oct 17 2010 05:28 PM
11 replies to this topic
Posted 17 October 2010 - 05:28 PM
Im looking at this 2000 f-150 and was asking a mechanic if there was any specific probs with this engine and he said the most probs he sees with this engine is oil pressure problems. This truck only has 84 thousand so thats good, and 5 speed. Anybody have probs with your 4.6? Thanks
Posted 17 October 2010 - 11:39 PM
I have a 99 F150 with 190,000 miles and my wifes 2000 expedition with 150,000 miles. Both have the 4.6 but one is a ceveland and one is a winsor. Never had a wrench on either one.
Posted 18 October 2010 - 04:59 PM
I thought Cleveland and Windsor described 351 engines of yesteryear.
Posted 19 October 2010 - 06:06 AM
Check the passenger rear coil pack for coolant residue. The heater hose above it likes to leak and creep inside the coil. Eventually causing a miss fire.
Also, check the door frames kinda where your elbow would ride with the window down. The power windows like to over torque the frame when closing, causing cracks.
Posted 20 October 2010 - 08:29 AM
I've got a '99 4X4 with the 4.6 and 5 speed with 98k miles and the only issue I had was a lazy fast idle. It took like 10 seconds when starting in cold weather to come to fast idle. Changed some bypass valve and it has been fine. I burn about a quart of oil between oil changes (3000-4000 miles). Not a particularily powerful motor, but tows an enclosed trailer with 4 bikes ok. Mileage is about 16 in town and 18 on the freeway without the trailer, about 13 with trailer. The 5 speed is kind of crappy, long throws and easy to grind gears, but all in all has been a reliable vehicle. If you don't have high expectations on power, you will probably be happy with it.
Posted 20 October 2010 - 05:41 PM
I have a 97, only 108k, never any issues although in a long bed 4x4 it is underpowered at least out West.
Posted 20 October 2010 - 08:30 PM
I believe the 4.6's(I cant remember if it was the 4.6 or 5.4) two piece spark plug design had a problem with the electrode part of the plug getting stuck in the head while the insulator gets pulled out cleanly. This can be changed by getting a one piece spark plug.
Posted 21 October 2010 - 01:12 AM
Two piece spark plug?
Just don't use anti seize on the "one piece" spark plugs during installation.
Posted 21 October 2010 - 05:23 AM
yz250_bm said:
I thought the 4.6 were described as romeo and windsor motors.
Yep your right. A few years ago i use to go on a f150 forum and they had a section where you could look at your door vin and tell what all the numbers and letters meant. I knew that my wife`s motor was different than mine, and as i posted cleveland came to mind. Growing up in the 70`s i guess i was thinking about the 351s.
But the big talk about the plugs over there were on the 5.4s. They seem to blow right out of the head quite often, the 4.6 it seemed rarely if ever.
Posted 23 October 2010 - 05:07 PM
I've got a 2000 ford F-150 ext cab 2wheel drive that has 87K on it. The only problem...knock on wood...so far is 2 coils packs that went bad. I picked up all 8 on ebay for 100 bucks and did them all at once. Runs great,gets descent mileage, and been a good truck. My only drawback is that its way underpowered and compared to some of the newer trucks I've driven it seems like the steering isn't as responsive as it could be. I am getting new tires this week, on my 3rd set. I plan on driving this beast until it drops.
Posted 25 October 2010 - 03:11 AM
One thing I noticed with both the 4.6 or 5.4s, is that the head gasket may weep oil from the passanger rear head. If its not too bad then I wouldnt worry about it and buy it. There is a TSB on this issue, and it states there is no cause for concern. But I bought my dads 98 f150 when the head gasket had a noticable oil leak, and I ended up having to change the head gaskets 3 months down the line. The 4.6 is still a rock solid motor, and we hardly run into any problems with them at work. I have only seen the plug blowouts on the 5.4s aswell. As long as your not looking for a big power engine, you will be happy with the 4.6.
