PW80 suspention upgrade?
5 replies to this topic
  • gcurren
Posted 16 October 2010 - 02:28 PM
Is there a suspention upgrade for the pw80? My son is bottoming it out on jumps. Or should I just not let him jump the 80?
  • Smacaroni
Posted 18 October 2010 - 06:29 AM
well, it's not quite made for jumping.
Check the PW 80 Questions thread.
http://www.thumperta...ad.php?t=738583
Page 28 (post 278) is the front suspension upgrade, still working on the rear.
http://www.thumperta...=738583&page=28
  • Curlytop
Posted 15 January 2011 - 10:39 PM
Smacaroni (or anyone else that has a picture or two!!), please may you post a picture or two of the position where to drill for the top rear shock mount.
I would love to get just a little more height for my daughter so that the bike doesn't quite feel so small.
  • Smacaroni
Posted 17 January 2011 - 06:57 AM
Oh, yeah, I get absent minded sometimes.
The reason I drilled this in this position is so it could be drilled again above that point for a slightly lower seat height, if needed. I'm guessing most people just drill a new hole straight back. The left side of the photo is the front, the original hole is also towards the front. I forget what I size I used, either 5/16", 11/32" or 3/8". Stock size is 11mm, IIRC.
  • Curlytop
Posted 17 January 2011 - 08:01 AM
That is almost exactly where I drilled my daughters bike last night.
The worrying part was where you drill thru just the edge of two layers of material.  I was worried the drill might skew off slightly and then not line up all the way true, but I got there quite easily in the end...
Thanks again for the pictures.  The US$25 Extender + shipping to where I live is just not worth the costs.
A Jeep brake rotor gives the stand a perfect height to lean on - without it the bike almost topples on it's stand. (I'll get to extending the leg at another time.)
Amazing how much just 1" difference will make to a total picture and outcome!!
  • Smacaroni
Posted 17 January 2011 - 08:08 AM
Obviously it's too late now, but I drilled the whole way through both sides with a 1/8" bit. Then, I moved up a size or two and drilled one side, then switched over to the other. This way if it does walk, it should walk in a nearly uniform pattern.
The stepped-steel won't affect the rigidity, since the single layer part is in the area of the least stress.
