kx 125 fork oil
6 replies to this topic
  • supermoto200
Posted October 15, 2010 - 06:04 PM
I need to know what weight fork oil i should use for my 2005 kx 125?
And does anybody know what the level should be at?
thanks
  • The Spanky
Posted October 15, 2010 - 06:31 PM
The standard oil is Kayaba 01 fork oil, which is 5wt I believe. And I think the standard oil height was 105 mm, +/- 20mm.
  • SAPPERS
Posted October 15, 2010 - 07:33 PM
yes, 5wt
2 ways to get level:
652ml +/- 4ml (22.04 +/- .14oz)
or
135mm +/- 2mm from top of tube, fully compressed, spring removed.
  • JJRace
Posted October 16, 2010 - 03:19 PM
http://www.kawasaki..../sp_KX125M3.pdf
  • The Spanky
Posted October 16, 2010 - 03:54 PM
yes, 5wt
or
Seriously? 135mm stock oil height? Wow. My '02 KX250 is spec'd to have a 75mm oil height, with an allowable range of 60mm-120mm. I run about 70mm.
  • SAPPERS
Posted October 16, 2010 - 06:55 PM
Yep, different forks. I have the pdf manual here on this laptop.
  • kawamaha
Posted October 17, 2010 - 08:00 AM
this is 2005 team green recommendation:
http://www.teamgreen...T_Sus_Chart.pdf
the level is about 90mm because they have bladder forks
only the 2003 forks differ, that year has no bladders.
since 2005 the KX250 has dual chamber forks and no oil level is specified but the oil volume. the KX125 kept the bladder forks until the end of production of the 2T
see all TG charts:
http://www.teamgreen...e_settings.html
Edited by kawamaha, October 17, 2010 - 11:04 PM.
Best trail bike by Ripley
  • Hot  103 replies
2006 KX250 Project by ItsJuniorJ
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • Hot  37 replies
I've tried everything to fix this, please help. by UglyCasanova
  • Hot  33 replies
options on swaping a 07 crf450r for a 2003 kx250 by 92rmx250
  • Hot  40 replies
Is the stroke coming back? by MazdaMan
  • Hot  180 replies
