2010 valve clearance reports?
19 replies to this topic
  • tech24
Posted October 11, 2010 - 05:31 AM
I'm coming up on 20hrs and figure its time for a valve check if I have time this weekend. Was just wondering if anyone has had to shim these things yet or if they are like the good old 5 valve heads?
I plan to reuse cover gasket anyone have problems with tearing during removal? (I'm being a tight wad and gasket isn't leaking)
  • aedwards07
Posted October 11, 2010 - 07:03 AM
Havent had to shim mine yet and im at 98hours.
  • tech24
Posted October 11, 2010 - 07:19 AM
Nice, now I wonder if I should even bother checking especially since it doesn't get ridden hard
Posted October 11, 2010 - 08:47 AM
If you've never checked, you should.
  • tech24
Posted October 11, 2010 - 08:49 AM
Yeah I will for at least piece of mind and as always maint is cheaper. For my riding I figure every 20hrs should be plenty but I haven't done it since break in so it really needs checked.
  • fraser
Posted October 14, 2010 - 02:49 PM
Checked mine at 30 hours, no movement at all. They were perfect
  • tech24
Posted October 15, 2010 - 04:05 AM
I think that will be the same for me, gonna check her out tomorrow
  • TX-SANDMAN
Posted October 15, 2010 - 03:45 PM
Tech24 - noticed you have a 2004 YZ450F too - how does the 2010 Low to mid range power hit compare?
Once I read all the reports about the off-idle hard power hit I tough "that sounds just like my 2004 bike". All the 06-09 YZ450's are nice and mellow.
  • tech24
Posted October 20, 2010 - 04:13 AM
Checked my valves and they are in spec. On a side note checked all my inkage bearings too and was suprised to find a nice amount of grease from the factory and they were in great condition.
The off idle hit on the 2010 is nothing like any other yz. Its not really power its a combination of instant throttle response from FI and throttle body design and low inertia from a light crank and flywheel.
The '04 is has a way more explosive power feel and broader powerband but may not be faster or have more power.
  • brentn
Posted October 20, 2010 - 12:20 PM
Has anyone re-used the head cover gasket on their 2010 after checking the valves and not had a leak?
I'm almost at 20 hours, thinking I should check at that point but not until I order a new gasket first unless someone tells me otherwise.
  • tech24
Posted October 21, 2010 - 04:40 AM
I reused it with no problem. It was in great shape and after looking at it I can't figure how any have torn or had any leaks. I just scrapped the gray sealant and used right stuff in its place.
  • CaptainKnobby
Posted October 22, 2010 - 01:29 PM
I need to check mine since I have 28 hours on mine. What did you mean "used right stuff",is that some type of sealant?
  • brentn
Posted October 23, 2010 - 10:56 AM
Hi temp RTV orange or equiv
  • CaptainKnobby
Posted October 23, 2010 - 04:55 PM
Oh!! I see
Posted October 23, 2010 - 05:33 PM
It's not just Hi Temp silly sealer, it's a duplicate of the RTV sealer used at GM dealers, and a big improvement on normal silicones.
http://www.permatex....asket_Maker.htm
I don't use any gasket sealer on the cam cover, and I've never replaced one except during a rebuild. The 2010 has been problematic, though, so I'd be more prone to stick it down with something. "Right Stuff" might work for that because it's that much better, but "normal" silicones in general are not well suited for sealing gaskets.
  • brentn
Posted October 23, 2010 - 08:45 PM
Good to know that you don't have to use it, it can get messy real quick, especially the orange crap on aluminum colored parts...
I did a bunch of reading before I got my bike about the cam cover issue with the 2010, alot of people started seeing leaks right away, some people were seeing them at the same time interval and they already had replaced it 3 times!
So far I have noticed no leaks at all on my own, seems to be a completely hit and miss issue with the 2010's...
  • CaptainKnobby
Posted October 24, 2010 - 06:17 AM
Mine hasnt been leaking either but I havnt had the valve cover off yet also.
  • tech24
Posted October 25, 2010 - 04:19 AM
you don't use it on the cam plugs? Thats the only place i use it but I guess it should seal without it but sealing cam caps and plugs is imprinted in my brain from autos.
Edited by tech24, October 25, 2010 - 05:51 AM.
Posted October 25, 2010 - 06:36 AM
If you mean the "half moons" on the left side, no. No sealer. On automotive engines, I used #3 Permatex. Silicone RTV sealers in general are a poor choice for sealing "rubber" gaskets. They're messy and prone to release from the gasket material.
  • tech24
Posted October 25, 2010 - 09:44 AM
Hmm ill try with no sealer next time cause I don't really care for scrapping all that crap out. I use right stuff for everything though never had an issue but it is messy and tends to act more like a lubricant at times.
  • 0 replies
  • 10 replies
  • Hot  50 replies
