Which link bearings?.. OEM, Pivot or All balls?
4 replies to this topic
  • xrberg
Posted October 10, 2010 - 09:46 AM
Just curious to know what you brand you guys use for lower link replacement needle bearing kits?
Can these be ordered from a bearing supply house?.. I see no numbers.
If aftermarket would you go All balls or Pivot... don't want crap but if the imports are ok I'll go that way
opinions appreciated
  • tech24
Posted October 11, 2010 - 05:28 AM
I use pivot works mostly since it comes with everthing in one package. Never had a problem. I grease them with amsoil heavy duty offroad grease and they last a long time. I have used allballs once on a quad and seemed quality except it came with plastic thrust washers instead of ones with bearings so never used again.
  • YamaLink
Posted October 11, 2010 - 08:54 AM
OEM will be the first choice of many and they do cost more.
There are some junk bearing options but the two you chose have had good reliability. Once in a great batch there will be a junker, but to say OEM is perfect all the time is not true.
You can call with the oem number and get an aftermarket match.
  • Gizler00
Posted October 11, 2010 - 09:32 PM
I would go with Pivot Works bearings. I have always used them and had alot of luck. Just as good as OEM in my opinion
  • slow hand
Posted October 12, 2010 - 08:36 AM
Yep, go with Pivot Works.
I made the mistake of trying some All Balls one time, and the needle bearings didn't even come with the styrofoam packing in them. Therefore, one or two of the needles fell out during shipping!
With the styro-packed ones, you can confidently install them without worrying about the needles falling out. Then, once installed, you can take the styro packing out and pack with waterproof grease.
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  491 replies
Need help by Goforaride
  • Hot  68 replies
  • 0 replies
