stuck slide!
4 replies to this topic
  • prestongravely
Posted 09 October 2010 - 06:53 PM
Does anyone know the best way to remove the slide from a carburetor when it is stuck? I've tried many cleaners and a little heat with a torch and it will not move.
  • XC700116
Posted 10 October 2010 - 08:20 AM
are you sure it's the slide and not the needle?
if not, try popping the needle clip loose if you can, ie, loosen the idle screw all the way out so it might let the slide drop down a touch to allow you to pull the, cable, lock plate, and needle clip out, then see if it moves. Chances are it won't and it's the slide but it's possible.
  • prestongravely
Posted 11 October 2010 - 09:15 PM
Yeah, i've tried taking everything apart. The sled sat for a couple years I was told so i'm sure everything is stuck. Runs good, just can't ride. Thank you for the info though. Any other ideas please let me know.
  • snow_junkie
Posted 12 October 2010 - 06:18 PM
i would get on the manufactures website and look for a carb diagram for your sled and take the whole thing apart, all the way down, clean everything and see if that helps, how ever (xc700116) has a great point, if his idea doesnt work sounds like the slide is stuck..... for good lol
  • ossakid
Posted 05 December 2010 - 07:52 AM
I have had good luck soaking in Kroil for a day or so.  Just squirt it now and then to keep it wet.  Time heals all!
