Trail Tech Vapor Installation question 08 YZ450
6 replies to this topic
  • mdkcrf250r
Posted October 07, 2010 - 04:53 PM
I installed the Trail Tech Vapor computer on my bike but the instructions say to splice power from the stator with no clear instructions as to which wire. From my understanding you only need power for the backlight. I have everything else hooked up (temp, rpm, speed) and everything works. I'd like to have the power connected too for the backlight but I'm not sure how to go about it. So what color stator wire do I splice into? Any preferable ground spot? Thanks for the help.
  • mdkcrf250r
Posted October 08, 2010 - 12:52 PM
Anybody?
Posted October 08, 2010 - 01:23 PM
IMO, there is no power source available for any auxiliary use on a YZ450. Certainly none is intended. It's an ignition only, all AC system, with just enough power for the ignition and no extra. The back light probably doesn't take much, but then again, if you don't have lights, why would you need it?
  • mdkcrf250r
Posted October 08, 2010 - 02:05 PM
I agree its not needed most of the time but I'd like to have it lit up so I can see it easily when riding the trails going through sun, shade etc. Just like the WR's. The instruction booklet says the vapor can work off anywhere from 6-400 VAC-VDC...I guess I better call their tech support.
  • mdkcrf250r
Posted October 08, 2010 - 05:44 PM
Ok I got it figured out. I called Trail Tech and they gave me the scoop. You get power from the stator. The Vapor can support anywhere from 6-400 VAC-VDC so hooking it up from the stator is just fine. Worst case scenario (which is unlikely) is the computer will draw too much and not allow the coil enough to fire, meaning the bike won't start. It will not damage anything on the bike or the computer itself. The wires coming from the stator go to a connector in between the radiators and right in front of the head. Splice power from the Green wire and ground from the black. Both wires are next to each other in the connector coming from the stator. Hope this helps someone.
  • TTR230KING
Posted July 10, 2013 - 09:29 AM
i know this is an old topic, but how long did the battery that is in it last? or did the whole computer run off of the stator?
  • Se77vN
Posted July 20, 2013 - 08:58 AM
I tried this on my 08, and the bike would not start. I eventually ended running a separate battery and switch to the unit to power it.
  • On January 15, 2017
  • 5 replies
  • Hot  113 replies
  • 0 replies
