Stepped over to the blue side.....YZ450F -11
32 replies to this topic
  • HRC
Posted October 06, 2010 - 12:24 AM
Hello Yamaha TT-people !
After 11 years riding Honda I got myself a 2011 Yamaha YZ450F !
Hope to get some good info and tips on what to think about when riding a blue machine.
First question....how many hours between oilchanges on the -10/-11 YZ450F ?
Anything I should check before first ride ? ( I know the usuall stuff like spokes, bolts etc, etc.....)
Any weak stuff that I should keep an extra eye on ?
Best recomended suspension settings / sag.....my weight is cirka 78 kg.
I´m really looking forward riding Yamaha ! It is always nice with something completely new.:smirk:
  • motojase316
Posted October 06, 2010 - 03:01 AM
Hey HRC,
Congrats on the new ride.
I do oil and filter every 5 hrs.
did you get my PM?
  • HRC
Posted October 06, 2010 - 04:15 AM
Hey HRC,
did you get my PM?
Hi there ! Thanks !
Yes I got your PM.....:smirk:
  • delmas
Posted October 06, 2010 - 04:45 AM
did you get the tuner
  • Mick17
Posted October 06, 2010 - 04:53 AM
What is the chamber on the head pipe for??? Why don't most of the aftermarkets have this???
  • Swapper265
Posted October 06, 2010 - 04:54 AM
They do, just in varying different styles.
It is mostly aimed at noise reduction !!
HRC - Welcome to the BLUE side. You will never go back!!!
:smirk:
Posted October 06, 2010 - 06:38 AM
First off, welcome.
What to check right away:
Grease: the factory uses minimal amounts in the steering head and linkage, and it doesn't look particularly water proof
Chain: Junk. Discard it before you damage two otherwise good sprockets. Stepping up to a really high quality chain such as Regina's ORN6 is money very well spent. And while we're on the subject read the manual regarding setting the tension. Yes, they really do need to be that loose.
Rummage through the common threads sticky. Be sure you understand that the YZ uses a dry sump oil system, and how that works.
Ask questions and have fun.
  • aedwards07
Posted October 06, 2010 - 08:04 AM
Are we going to see a HRC works yamaha like your hondas in the past?Keep an eye on valve cover gaskets too.
  • brentn
Posted October 06, 2010 - 08:59 AM
I change my oil often so I buy in 4L jugs, Castrol GTX 20W50. I do a change only every 2 hours on this bike, I do about 3 oil changes before the filter is changed. There really, IMO is no need to change the filter any sooner than that cause it doesn't get dirty that quick. The air filter on this bike is great, it's position keeps it clean for a long time. I have gone about 8 hours on a filter without cleaning and it was just starting to get dirty. If I compared that to my older YZ250 with the filter in the rear, after 3-4 hours it would be just CAKED in brown dirt.
If you recieved the tuner, try the Jay Marmont map, makes the bike HAUL. I love it!
  • HRC
Posted October 07, 2010 - 12:07 AM
No ....should I get it ? Is it worth the money ?
  • HRC
Posted October 07, 2010 - 12:08 AM
First off, welcome.
Thanks ! :smirk:
  • HRC
Posted October 07, 2010 - 12:09 AM
All I can say is.....I got big plans for my Yami ! :smirk::p
  • YamaLink
Posted October 07, 2010 - 05:08 AM
I'd change the oil filter every other oil change, too.
At 78kg is about 173 pounds. Set your sag at around 99 to 102mm and see what works best for you.
Posted October 07, 2010 - 06:57 AM
The GYT-R tuner is pretty simplistic has electronic EFI/IGN remappers go, but very useful nonetheless, and not that expensive. FMF offers one that I know nothing about that may be more capable or not.
The cool thing about the GYT-R unit is that it can be used anywhere (like at the track) and can store several maps that you've already tried. That can allow you to make on the spot changes to suit conditions as you might want to if the track is unusually wet or dry one day, and do so in a matter of seconds.
It also is a totally standalone unit requiring no computer or extra hardware. In one sense, while the simplicity can be a little limiting (there is a total of 9 cells each for timing and fuel), the other side of that is that it's easy to understand and quick to make changes to.
I would say it clearly isn't the most sophisticated unit of its kind available, but it's certainly worth having, yes.
  • Thumper38
Posted October 07, 2010 - 09:43 AM
Its worth every penny! very nice tuner!
  • HRC
Posted October 07, 2010 - 11:07 AM
OK...thanks !:smirk:
  • Ga426owner
Posted October 07, 2010 - 11:47 AM
Wow I never thought I would see the day HRC.......welcome to Blue. I can't wait to see what is in store for your yami :smirk:
  • HRC
Posted October 07, 2010 - 11:16 PM
I can´t wait to start pimping it ! :p
Some parts are ordered and coming next week. :cheers:
  • Ga426owner
Posted October 08, 2010 - 06:21 AM
I can´t wait to start pimping it ! :smirk:
Some parts are ordered and coming next week. :p
r u planning on leaving the KYB or going exotic with ohlin?
I highly recommend you buy the tuner, dump the chain immediately.
I can not wait for a full ride report
  • tech24
Posted October 08, 2010 - 09:21 AM
Yes get the tuner, its also has built in diagnotics and an hour meter. And RM sells them for good price.
You asked about sag from reading on here I have seen many setting it to 110+. I have mine at 115 and couldn't be happier but I'm no racer. From the way it sounds a little extra sag or lowering link is desirable on these.
  • Hot  113 replies
  • 0 replies
  • Hot  47 replies
