2010 power tuner question
12 replies to this topic
  • no air charlie
Posted October 03, 2010 - 07:40 AM
I purchased the GYTR power tuner to remap my bike. I am not very computer literate but they made loading up the maps very easy. It is truly user friendly.:smirk:
My question now is how to get the clip unhooked at the front of the bike? The manual shows it unpluged but doesn't say how. Do you squeeze, pry or snap this thing off? I really, really, don't want to break it.
I am beginning to think I am too old to own a bike like this. I have dropped more f bombs working on this bike than any bike I have owned. It seems like the manual assumes we all have Grey Racers mechanical experience, but when it comes to electrics I am clueless!
  • steve_97060
Posted October 03, 2010 - 08:00 AM
I had the same problem when I tried to use it for the first time also. There is a small clip/tab inside of the connector, run your fingernail just inside of it and you should feel it. then just depress it and it slides right out.
  • no air charlie
Posted October 03, 2010 - 08:28 AM
Thanks for the quick reply. Are you talking for getting it off the aluminum clip attached to the frame or to get the plug apart? So far I am not having any success with either.
Do you need to detach it from the frame? It looks like the plug has two "catches" on each side of it to keep the plug hooked together.
  • steve_97060
Posted October 03, 2010 - 09:47 AM
it stays on the frame, I am referring to the plug.. there is a thin tab on the outward side about in the middle that you depress and the plug slides out.
  • brentn
Posted October 03, 2010 - 11:00 AM
I actually shaved down the little nub that locks it in so that when I pull it out now it is much easier to get out, but doesn't come out on it's own.
  • no air charlie
Posted October 03, 2010 - 04:22 PM
I see the "release" you are talking about but even with that pushed inward it will not come out. I can wiggle it slightly so its not "stuck" but no luck removing. I would welcome any more ideas.
On a side note I have noticed that after riding the seat is bowed slightly making the back of it stick up slightly from the rear fender. If you loosen the seat bolts it straightens back out. Not a big deal but kind of weird. Anyone elses seat do that?
  • steve_97060
Posted October 03, 2010 - 07:30 PM
charlie, just press on it and pull the plug out of the connector.
  • delmas
Posted October 04, 2010 - 04:19 AM
you have to get your finger nail and pull the release catch out not in
  • no air charlie
Posted October 04, 2010 - 05:55 AM
THANK YOU!!!! Delmas is right I pulled that little release outward and it popped right out. I have to say I was about ready to drop kick this thing off a 20 ft cliff yesterday. This site is invaluable with the help you get, I had given up on it till I read the thread again.
  • delmas
Posted October 04, 2010 - 07:15 AM
great glad I could help
  • sean3239
Posted October 12, 2010 - 09:38 PM
Yes, my seat has done that now too, something like a 3/4 inch gap above fender. Good thing the airbox is not back there anymore!
  • no air charlie
Posted October 14, 2010 - 05:50 AM
Must be a 2010 glitch. I know the seat is on correctly and will admit that I am a big guy at 215 without gear but I have not had any previous bikes do that. It seems like maybe there is not enough support from the subframe in the middle of the seat so when you seat bounce it pushes the seat down slightly in the middle raising the back of the seat up.:smirk:
  • gfmoto
Posted October 14, 2010 - 07:41 PM
Where were you when I broke mine trying to get it off!:p that thing really pissed me off for about 10min!:smirk:
  • Hot  36 replies
  • 10 replies
  • Hot  47 replies
