Help! Just rebuilt and fitted engine, not charging and no lights!
3 replies to this topic
  • 04WR450man
Posted September 30, 2010 - 07:54 AM
Hi all :smirk:
I have just re-fitted my 2004 WR450 engine after a rebuild (Chain snapped and wiped out the case) the engine started after 3 secs on the button :smirk: but, now the lights dont work and its not charging the battery.
I have checked, re-checked and checked everything again...............
The only thing that has changed is the left side case is now a 2003 item, as the chain snapping indecent smashed a hole in my 04.....
Can anyone suggest anything, please :p:worthy::cheers:
Mant thanks
  • William1
Posted September 30, 2010 - 10:31 AM
Did you re-connect the fat ground wire?
Did you pinch a stator wire?
Check all plugs?
Check the fuse?
  • 04WR450man
Posted September 30, 2010 - 12:14 PM
Hi, thanks for the reply :p
Yes, ground is connected, fuse is good and the stator and all other plugs are good............
Now, I just bolted on my spare 2003 stator/side cover and the bike wouldn't start................(I have a spare bottom end, so have all the 03+04 parts, but the 04 crank/flywheel etc is the one I am using)
Are the 03/04 stators compatible?
I am stumped.............
Thanks :smirk:
  • William1
Posted September 30, 2010 - 01:40 PM
You need to test the stators by the manual. Continuity bettween segmantrs and contimuity to ground.
