What is the most distance anyone has gone without major engine work?
7 replies to this topic
  • Garry
Posted June 29, 2003 - 02:56 PM
I have durability related questions directed to those with a lot of miles/kms on their WR4.
At this point I have 6,000 miles/10,000 km on my WR426
Being aware of the great variety of usage conditions, but assuming good maintainance:
1.) What is the most distance anyone has gone without major engine work?(opening the engine)
2.) What is typically the first point of failure/wear in the WR4 motors
3.) What is the typical miles/kms before major engine work?: (rebore/valve work/cam chain..)
Honda XRs could seemingly do 18,000miles/30,000km as a max before cam chain wear/valves required a rebuild. From our collective experience, does a well maintained WR4 match this?
  • Indy_WR450
Posted June 29, 2003 - 03:07 PM
I think the WR engines are good for 10,000 miles under non racing conditions. You need to do your valve clearances once a season. :)
  • SMD
Posted June 29, 2003 - 05:55 PM
I would agree with Indy.There are several WR4's in our group with 6 to 8k and one due to hit 12k this summer again under non-racing conditions. Each with nothing more than a valve adjustment.Its a strong design. :)
  • blue_beast_wins
Posted June 29, 2003 - 06:51 PM
I had my motor torn down at about 6000 k's for gear box failure, i did fit a new piston and rings at that time just because.......well........ it was apart, going by what i saw at the time i think these things (well maintained) are good for 15-20,000 K's, the thing's that will stop this kind of milage are the gear box and the timing chain :)
I have 8,000k's on mine now,
Try pm "Sabin", he'd have to have around 14,000 k's by now.
  • MotoLocoPat
Posted June 30, 2003 - 12:47 PM
I run Moto-Loco.com tours using WR-426's 2001 models. My "Personal" 426 has approximately 12-14,000 miles on it and it is running as good as new. another has about 7K and another around 5K. No problems from any, no noises no leaks. I just change the oil and clean the filters regulary but during a tour they go until the end of tour without a change which is about 800-1000 miles. I expect mine to go 20K easily. I would get on it right now and go on a 2000 mile trip. I do run a Scott's stainless steel filter on all of my bikes. Better filtering qualities :)
  • emcdan
Posted July 01, 2003 - 05:35 AM
I bought a new yz400 in '97. Rode the crap out of it. Adjusted the valves once after a year. They never tightened up again. Changed oil every couple of rides (nothing but Honda HP4) I was always tempted to take it apart and check upper/lower end but didn't. I have no idea the mileage but I'd guess between 20K and 25K. Never a problem with it. Most of these bikes are incredibly resiliant. :)
  • the426master
Posted July 01, 2003 - 05:40 AM
i have 4623miles on my 426 but you half to do the valves often I do mine in the winter. :)
  • sabin
Posted July 03, 2003 - 09:34 PM
you are almost right I have about 15000km now. I have adjusted valves once and that's all. I have no notisable oil consumation, bike rips. I guess I'll have to change cam chain and rings soon. I change oil on every 700-800 km. (when it changes color)
