Hole in end of throttle tube
9 replies to this topic
  • spud
Posted June 29, 2003 - 11:17 AM
I usually ride with bark busters,and short bars. I want put my big bars back on without the busters. Anyone find an easy (HOME MADE) way to cover up the cut off throttle tube end, that looks ok. I want to avoid any possibility of a stuck throttle..
  • yamahasocal450
Posted June 29, 2003 - 11:24 AM
takea soldiering iron or a welder or a low heat torch and melt a piece of plastic (cut to shape witha dremel) to the end of the throttle tube then put expoxy over theparts that look unsealed :)
  • RPS
Posted June 29, 2003 - 11:40 AM
Moose make some bar end that you can use for about $14. I use them om my bike even thoug I dont run handguards. The save grips on diggers. Send me your e-mail and I will send you a pic or check out: http://www.gobike.com.au/prod2621.htm for to somthing similar.
Roger
  • spud
Posted June 29, 2003 - 02:24 PM
MY plastic welding skill has problems, I was thinking of sticking a WD40 can lid over the end ( if it fits)and then a new grip or something similar :). Will those after market bar ends still let in the dirt under the tube ? thanks for the ideas :D
  • Indy_WR450
Posted June 29, 2003 - 02:44 PM
By the metal throttle tubes. The plastic stock ones can crack when drilling. I went thru the first set and have since gone with metal tubes. :)
  • BlueThunder
Posted June 29, 2003 - 08:45 PM
Who makes a good billet throttle tube Indy? All the ones I see are for single cable smokers but I'd really like to invest in one.
  • Indy_WR450
Posted June 30, 2003 - 06:57 PM
Fastway makes great billet throttle tubes
http://www.mountains.../throttletubes/
http://www.mountains...m/salespage.asp
$25.00 and they are solid. You wont wear these out.
  • BlueThunder
Posted June 30, 2003 - 09:31 PM
Thx Indy........got one on the way. Those are a nice looking piece.
  • Math
Posted July 02, 2003 - 08:31 AM
I did the WD40 mod :D I putted the red can lid under the throttle grip but it broke easily in several pieces... :)
  • IceBox
Posted July 02, 2003 - 08:50 AM
Any idea what is different between 98-00 WR's and an '03 WR450 throttle tube?
