2010 cover above spark plug
14 replies to this topic
  • no air charlie
Posted September 27, 2010 - 09:38 AM
I am pretty sure this has been on here before but I searched and couldn't find it. There is a plastic shield below the gas tank and directly above the valve cover spark plug area. The manual simply refers to it as a cover and gives no instructions on how to remove. There are two plastic pins at the back that hold it on. From the diagram in the book it appears like they just "snap" in. This apparently isnt the case as I managed to break one while removing.
Anybody know the right way for removing these? I am going to buy a couple of extra for future use as you can not get to the spark plug without removing this cover.
Grey, this might be a good procedure to put in a sticky for the 2010/2011 bikes. Hopefully it will prevent future owners from making the same mistake.
  • eazrider
Posted September 27, 2010 - 09:49 AM
Take a small pair of pliers and gently pull the center of the snap "up"....this releases the insert that goes into the frame and allows the "cover" to be pulled towardsthe rear and removed. It has 2 tangs on the front that retain it on the front, and just pulls out once the inserts are removed....
  • andy250
Posted September 27, 2010 - 09:52 AM
No... You push the center pin in to release the inserts. I use a small t-handle allen wrench.
Posted September 27, 2010 - 10:07 AM
Yep, that's how they work: push the centers in a until they click to release the fastener, then lift it out. Push the center pin back up flush with the top again before reinstalling it.
Don't push too hard or far, or you will push the center pin out of the fastener and possibly loose it.
All that's in the manual, you know.
  • brentn
Posted September 27, 2010 - 10:10 AM
What page cause I couldn't find it?
I ended up with the center pins pushed in and yanked the whole thing out in frustration. It looked to me like you had to have the center pins up and slightly out in order to remove the shield... but I guess I was wrong..
Posted September 27, 2010 - 10:20 AM
OK, I can't locate that info in print, either, but those are a common type of Japanese snap fastener. Push them in to release, back up to reset. You might also find that it's easier to release them and pop the cover out with them still in place, as you said, but that is how they work, nevertheless.
  • no air charlie
Posted September 27, 2010 - 10:58 AM
Thanks for the response. Grey, I looked through that manual 3 times and could not find anything for this cover. They might be common fasteners to the Japanese but in 30+ years of riding dirt bikes they are a first for me.
Posted September 27, 2010 - 11:01 AM
This would be the first dirt bike I've seen them on, alright. Quite common to the automotive world though.
  • honda907
Posted September 27, 2010 - 08:27 PM
I asked this same question back in March or April. I found it, but not on the page you would expect. It is on page 1-11. "REMOVING THE QUICK FASTENER". It just shows a picture of the "rivet". I will have to say, it is located in a rather obscure location in the manual. Yamaha doesn't talk in the manual about removing the plastic part above the spark plug with these fasteners. I found it by chance.
Actually, I was doing some work on the computer, saw this and went out to get my manual, so Grayracer can quote the page the next time this comes up.
:smirk:
  • brentn
Posted September 27, 2010 - 09:05 PM
btw, I don't understand how the pin can remain in the "up" position as the tank sits right on top of this area. There would be no room for the pin to remain popped up to secure the head cover.... :smirk:
  • Swiss_Dirtrider
Posted September 28, 2010 - 12:33 AM
:p
they don't have to remain "up", the are just "even" with the cover when installed
Posted September 28, 2010 - 07:49 AM
I knew I'd seen it. I'll remember it next time. :smirk:
btw, I don't understand how the pin can remain in the "up" position as the tank sits right on top of this area. There would be no room for the pin to remain popped up to secure the head cover.... :p
Read the page referenced. Explains the whole thing with pictures and everything.
  • brentn
Posted September 28, 2010 - 09:45 AM
:cheers::p
Yes I see now... I'm an idiot :smirk:
  • no air charlie
Posted September 28, 2010 - 01:20 PM
:cheers::smirk:
+1 I was cussing at yamaha for leaving this out of an otherwise detailed owners manual and it was in there the whole time.:p
  • BBrown626
Posted November 21, 2010 - 05:57 PM
I ended up breaking the heads on them. I bought a bag of 6 or 8 replacements at NAPA for a couple bucks.
  • 0 replies
  • Hot  47 replies
  • Hot  28 replies
  • 3 replies
