Shift, clutch and brake levers ?
Started by
hm450
, Sep 27 2010 08:31 AM
15 replies to this topic
Posted 27 September 2010 - 10:15 AM
Not only are they compatible, but in the US they are actually the same parts.
Posted 27 September 2010 - 11:16 AM
Thanks !
Do you think air filter is also the same on 450Z and compatible with X ?
Posted 28 September 2010 - 05:55 PM
hm450 said:
Thanks !
I haven't compared them side by side, but I would bet that they are the same.
Posted 29 September 2010 - 10:40 AM
Not smaller on X ?
Posted 01 October 2010 - 08:48 AM
hm450 said:
Not smaller on X ?
I doubt it, even though the air box is slightly different the rest of the air box is the same. Try pulling the part number for the filter cage, if it's the same then it's also the same for the filter.
Posted 02 October 2010 - 10:05 AM
Good news ! it's tough to find out some after markets stuff for X, so if Z parts are compatible
Posted 08 October 2010 - 10:57 PM
The filters betweem the X and the Z are different. I have both and the X is way smaller.
Posted 04 November 2010 - 10:11 PM
FYI, there's an exhaust guard available for RMZ450, in UK...see ebay.co.uk
Just bought one
Just bought one
Posted 20 March 2011 - 03:05 PM
anyone know if the clutch basket and the rest of the clutch components are the same rmx450z vs. rmz450?
Posted 27 April 2012 - 12:54 AM
Any one know a gear lever that is compatible with the rmx 450
I tryed a 2004 rmz 250 one dosent fit. Looked compatible.
No aftermarket one available......and stock is $119. au
Posted 14 May 2012 - 09:03 AM
Check out motosport.com website they have part numbers for the Suzuki RMZ and RMX you can compare the part numbers before buying parts. I just put new clutch plates in mine and it turns out they have a different setup. I tried an aftermarket RMZ clutch pack first but it didnt work with my rekluse and i burnt it to pieces then i got oem and its fine. There are two types of friction and steel in the oem packs to better deal with the heat build up. The RMZ looks like it has a different gear ratio on the primary drive.
