yamaha wr 400 turn signal ?
3 replies to this topic
  • fooloop
Posted September 25, 2010 - 07:03 PM
Can you wire signal lights on a wr 400 ? Because I know it's AC voltage and with signal lights it need DC voltage? How can I change AC to DC and will it push enough power for LED turn signal ?
  • redneckj
Posted October 01, 2010 - 09:28 AM
Just use a cheap flasher and it will work fine. Depending on current draw from the other lights you might have to rev it up a little for the flasher to flash. I am thinking about doing the floating ground mod and add a battery so I dont have this problem and then I can add a HID headlight system too.
  • austinmation
Posted October 01, 2010 - 09:43 PM
http://www.farplaces.com/dual.htm
  • fooloop
Posted October 02, 2010 - 08:33 AM
Thanks that link is just want i wanted :smirk:
