No Compression with new top end.
6 replies to this topic
  • dbehr624
Posted September 24, 2010 - 07:48 PM
Okay guys, I am stumped. I recently put a new top end in my '06 and when i put everything back together there was no compression. I rechecked my timing today and made sure the decompression release was in proper working order. As to my knowledge my valves were perfect when I put it back together. I will pull my head off again this weekend, but I need something else to check. Any suggestions?
Posted September 24, 2010 - 08:28 PM
If you remembered to put rings in it, then you need to check your valve clearance to start with. After that, then check your timing again by using a probe on top of the piston to locate TDC. Once you find it, check to see that the mark on your flywheel agrees with it. If it doesn't, you dislodged the flywheel key.
  • dbehr624
Posted September 24, 2010 - 08:39 PM
yeah, i put the rings in, so ill check my valve clearance again. I doubt my flywheel key is dislodged, but its always a possibility i fudged it up somehow...:ride: But thanks for the info gray. if it doesnt work, ill be back.
  • dbehr624
Posted October 03, 2010 - 11:10 PM
Well my valves checked okay and flywheel key was in place. Is it possible I put the rings in incorrectly?
Posted October 04, 2010 - 07:49 AM
Sure, but it's hard to see how you could have goofed them up so as to have no compression, rather than just low compression.
  • yzf225
Posted October 04, 2010 - 08:04 AM
Are you sure all the shims are in place in the buckets, if they are dislodged it may be holding a valve open.
  • eazrider
Posted October 05, 2010 - 09:24 AM
Pressure test the topend through the spark plug hole and see where it is leaking...
  • 0 reviews
  • Hot  36 replies
  • 0 replies
