WR450 Ignition Timing
1 reply to this topic
  • curtis916
Posted June 27, 2003 - 08:17 PM
Is the ignition timing adjustable? My motor pings sometimes under load at light to medium throttle (2nd gear). I have increased the main jet to a 160 and the pilot to a 48 and 2 1/2 turns out on the pilot screw. Using preminum gas. I did have the keyway shear and the dealer fixed it, but I was wondering if the ignition timing changed or was set properly. If anyone has any ideas I would appreciate it.
  • Indy_WR450
Posted June 28, 2003 - 03:58 AM
You have to go with aftermarket ignition. I hear that Vortex has the best system for the YZ450's. I have not had problems with the stock yet. I will replace it with the Vortex this winter.
